- Member since
The white was caused by using too much thinner, and/or spraying from too far away, causing some of the spray atomized Dullcote to dry in the air before it got to the model. This usually also has a gritty texture as well as the whiteish color. I don't use Dullcote anymore, switched to Polly Scale Flat, but I have used it extensively in the past. I usually only thinned it about 20%, using lacquer thinner, sprayed at about 20psi from about 3". But that's with my compressor/AB set up, youre set up could vary.
Regards, Rick
RICK
![](http://img.photobucket.com/albums/v236/rkinsey/USAflag.gif) ![](http://img.photobucket.com/albums/v236/rkinsey/NAWGBBadge1.jpg) ![](http://img.photobucket.com/albums/v236/rkinsey/bobgbspit.jpg)
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
