Let the acrylic cure THOROUGHLY, as in 48 hours to be safe. Spray the first several coats of laquer VERY thin, as in mist coats, and then let it dry thoroughly between coats. Laquer is pretty aggressive and can easily eat acrylic if you aren't careful.
I use MM Metalizers over acrylics frequently, but I always hold my breath when I do it.
