massive sputtering problem?
Posted by Anonymous on Sunday, October 31, 2004 12:09 AM
see topic name. 155 is sputtering like mad, with really really grainy spray. think taking a paintbrush and dipping it in paint and flicking it. that's what it looks like. nothing mechanical. works fine with tamiya acrylics, only this new paint i bought (apple barrell craft paint) so what's wrong with it?
Posted by Anonymous on Sunday, October 31, 2004 1:14 AM
is the paint thinned enuf? i had the same prob when i tried some auto paints with my anthem... fixed it by thinning the paint some more
Posted by Anonymous on Sunday, October 31, 2004 1:30 AM
Check your psi; high psi will make the paint dry before it even hits the surface of the model. 40 and above will garentee this. Also, check that you've thinned the paint properly - lack of thinner will also cause paint to fleck. Also, painting more closely to the model will help lessen the occurances of sputter. But of course, I'm probably stating what you already know Wink [;)]
good luck man Sleepy [|)]
    August 2004
Posted by jdavidb on Sunday, October 31, 2004 6:35 AM
Have you used a machine stirrer yet? You know, the dangerous Dremel schemes we came up with in another thread or the Badger mixer. That's how ya really liquify some thick paint. I've even succeeded in beating tiny clumps of cured pigment back into being airbrushable with a Dremel and a toothpick.
    January 2004
Posted by MusicCity on Sunday, October 31, 2004 6:41 AM
Ryan I think you've got some paint that just plain won't go through your nozzle properly. It builds up in the nozzle until the pressure blows it out and you get this splat-splat-splat effect. IF you have a larger nozzle try that, if not try thinning the paint a LOT (like 1:1) and see if that helps.
I had a similar problem with some paint once. I kept thinning it until it was basically just thinner, and kept running the pressure up until I got to something ridiculous like 40 psi. It finally blew but it looked terrible.
Posted by Anonymous on Sunday, October 31, 2004 7:49 AM
what kinda paint is that ? apple barrel ? what was its intended application ?
Posted by dtraskos on Sunday, October 31, 2004 8:10 AM
1337,
Junk the 155 and get an AztekBig Smile [:D]
Posted by Anonymous on Sunday, October 31, 2004 8:17 AM
Thin your paint
    August 2004
Posted by Tankmaster7 on Sunday, October 31, 2004 8:21 AM
Naah, the aztek has many problems on its own spraying regular model paints, forget some other brands. I speak from experience. Still saving for that anthem...
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Sunday, October 31, 2004 12:47 PM
It can be your paint. A lot of craft paints are very low quality and they don't thin well or spray good through airbrushes. I would try different paint.
John
Posted by Anonymous on Sunday, October 31, 2004 12:49 PM
aw man, Just when I got the perfect mixed tone for my custom case, it stops working on me. I don't have a larger nozzle unless I buy an iwata revolution (no way saltydog) and I've thinned the paint beyond thinning.
Posted by MikeV on Sunday, October 31, 2004 1:47 PM
John
I think John hit the nail on the head with his answer.
Those paints are made for crafts and they are best applied with a brush as the pigments are fairly large.
If you want to try an acrylic paint like that then pick up some Createx or Aqua Flow and use it. It must also be thinned some as it needs about 40 psi minimum to spray out of the bottle.
Posted by Anonymous on Sunday, October 31, 2004 1:53 PM
aw man, is there any better way to spray them, ie grind up the pigments?
Posted by MikeV on Sunday, October 31, 2004 1:55 PM
No, you cannot grind the pigments in the paint.
All you can do is try and spray them at higher pressures so that they will atomize better.
    July 2003
Posted by saltydog on Sunday, October 31, 2004 4:26 PM
typical badger results IMO!!!Wink [;)]Tongue [:P]Clown [:o)]Big Smile [:D]
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    July 2004
Posted by tho9900 on Sunday, October 31, 2004 4:35 PM
I learned early with mine you have to thin pretty good with it... I went from 2:1 on my 175 to 3:2 on the 155 on the same bottles of paint, a little more for certain types of paint...
::rolling eyes:: Chris reminds me of that one guy at the comedy club that always yells out "Get off the stage" everytime a new comedian comes out for their act...
Laugh [(-D]
Just kidding Chris... one day I will come over to the dark side too... you'll see... Wink [;)]
    July 2003
Posted by saltydog on Sunday, October 31, 2004 8:14 PM
its not dark over here Tom.............its very bright!!!LOL
Posted by MikeV on Monday, November 1, 2004 7:18 AM
Chris,
Iwata's are more picky with paints then Badger's are. Tongue [:P]
Posted by ajlafleche on Monday, November 1, 2004 7:55 AM
Mike and others have it. Not the paint for an airbrush.
You want a great looking model and you economize on on the very part that will be seen the most, the paint. This is the classic penny wise, pound foolish. It would be like getting a 300 watt high quality amp and playing it through a 1969 VW AM radio speaker. You're willing to pay $30, $40, $50 or more for a model (plus all the accessories) then you turn around and buy cheap jack paint.
    July 2003
Posted by saltydog on Monday, November 1, 2004 5:48 PM
QUOTE: iwata's are more picky with paints then Badger's are
not mine!!Wink [;)]Smile [:)]
Posted by MikeV on Monday, November 1, 2004 8:15 PM
I forgot that you have magic airbrushes Chris. Tongue [:P] Laugh [(-D]
    July 2003
Posted by saltydog on Monday, November 1, 2004 9:39 PM
oh i forgot.............you believe everything you "read" from magazines.............LOL later.
Posted by Anonymous on Monday, November 1, 2004 10:02 PM
what do you mean? according to fsm issue #1729 volume 2 revison 3.10, iwatas are nice but badgers are nicer :D:D:D:D:D
Posted by MikeV on Monday, November 1, 2004 10:38 PM
No Chris that was from the horses mouth so to speak.....Ken Schlotfeldt.
He has a little bit more experience than either of us. Tongue [:P]
    July 2003
Posted by saltydog on Tuesday, November 2, 2004 4:17 PM
ooooooohhh!! WOW!! "Ken" said it!!!! i'm sorry!! later. Wink [;)]
Posted by Anonymous on Tuesday, November 2, 2004 6:08 PM
yeah, he has more experience than all of us. combined. x 2. squared. over.000000001.
    July 2004
Posted by tho9900 on Tuesday, November 2, 2004 6:14 PM
could be swiggin on the old jar of Tenax again Mike... he's already fessed up to it in the past! Wink [;)]
    July 2003
Posted by saltydog on Tuesday, November 2, 2004 6:47 PM
nahhhh..........i just have raw talent, not magic airbrushes!!!!Big Smile [:D]Tongue [:P]Smile [:)]
Posted by Anonymous on Tuesday, November 2, 2004 7:25 PM
if you have talent, you don't need iwata
Posted by MikeV on Tuesday, November 2, 2004 9:03 PM
My thoughts exactly. Laugh [(-D]Laugh [(-D]
