Omni 4000 Problem...
    July 2003
Posted by lizardqing on Sunday, November 28, 2004 2:11 PM
I have not had this brush for too long now and it has been great. All of a sudden today it is spraying while just pressing the button down and not pulling back, also spraying a bit of a rough finish. Is something out of whack that needs to be adjusted or what?
    January 2004
Posted by MusicCity on Sunday, November 28, 2004 3:14 PM
The needle is not far enough out, probably from where you cleaned it last. Loosen the chuck at the back of the needle, push it forward until it just seats against the nozzle, tighten the chuck.
Posted by Anonymous on Sunday, November 28, 2004 3:35 PM
I agree with MusicCity , it is because the needle is not in the nozzle properly which will happen after cleaning if you don't push it in properly! You should use lube to lube up your needle this makes tip drying paint to not happen and helps with the spray to come out cleaner.
    July 2003
Posted by lizardqing on Sunday, November 28, 2004 5:04 PM
Thanks guys, I'll give that a try. Don't have any lube though. Guess I need to try to find some.
    July 2003
Posted by lizardqing on Sunday, November 28, 2004 5:13 PM
Yup, that seemed to have fixed it. Thanks.
    July 2003
Posted by KJ200 on Monday, November 29, 2004 7:28 AM
Mine did the exact same thing when I first cleaned it.
All part of the learning curve.
Karl
