Badger 360 question
    January 2003
Badger 360 question
Posted by plasticmod992 on Sunday, December 5, 2004 9:40 AM
Any Badger 360 owners out there that can advise me on their experiences with it, spicifically; ability to do fine lines (how fine?), work flow (speed of operation), atomization of paint, and your thoughts on it performance compared to similar A/B such as the 155, 175, VL, etc. I'm concidering purchasing one for the wife and I. All the research, posts and product decriptions have been very informative, however, I'd like to hear what actual users have of this A/B. Any insite would be appreciated. Thanks in advance!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    July 2004
Posted by tho9900 on Sunday, December 5, 2004 9:52 AM
I don't have the 360 but do have the 155 which is identical except for the fact mine is siphon fed and the 360 is either siphon or gravity... the only complaints I have heard about the 360 is using it in gravity feed you can only get 3 or 4 drops of paint with thinner added in the little cup. So even for detail it would require frequent filling.
As far as general performance it is similar to the 155 as it is the same brush with a twist (literally Wink [;)])... with the 155 I got fine lines out of the box, and with a little practice and getting in real tight with them.
Doing a tri-color WWII USN pattern on a plane I was able to spray the fuselage over the wing with no masking and there was no overspray. It also does good medium coverage, although for 1/48 bombers and such I plan to use my 175 as it does better at large jobs.
Cleanup is where I love this brush... and it woud be the same for the 360. Spray some thinner, back flush, spray more clean thinner, wipe down the needle and lube.. thats it! (well of course clean the cup too) takes maybe a minute or so to do it!
I mostly use the metal color cup when spraying small pieces or detail and imagine it is "close" to what gravity feed does... with properly thinned paint I am getting lines down in the 1/16th size range... (need more practice as I am not consistent yet, but it does the job)
Although I like my 175, the 155 (360 without the cup) is much better for detail... I think the 175 would do it with more practice but I like my 155 too much and it's so much easier so I take the easy route... The Paasche VL while a good brush would compare more to the 175 than the 155/360 brushes...
Hope this helped!
    January 2003
Posted by plasticmod992 on Sunday, December 5, 2004 10:07 AM
Tho9900,
Thanks, I appreciate it!
    August 2004
Posted by Tankmaster7 on Sunday, December 5, 2004 10:37 AM
yes, the 360 is almost the same as the 155. I have a 155 and it's wonderful!
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
