removing paint
removing paint
Posted by Anonymous on Thursday, December 16, 2004 9:45 AM
I have several old model kits and dealer promo models that i would like to remove the paint from. I Have removed the paint from the flat areas, but sanding will remove the details molded int the plastic.
    January 2004
Posted by MusicCity on Thursday, December 16, 2004 2:46 PM
Posted by Anonymous on Wednesday, December 29, 2004 7:44 PM
Thanks to all who told me about Castrol Super Clean, it works great removed all the paint with out any work but light brushing with a soft tooth brush.
Thank again
Posted by MikeV on Thursday, December 30, 2004 1:04 AM
That Castrol is some great stuff isn't it?
Glad to hear you got it worked out.
Posted by Anonymous on Thursday, December 30, 2004 1:28 AM
I've never seen any in stores over here in NZ, what else is a good paint striper mostly for acrylic paints?
Posted by MikeV on Thursday, December 30, 2004 2:00 AM
Easy-Off oven cleaner in the yellow can is good.
I have also heard of good results on acrylics with Simple Green cleaner.
Posted by Anonymous on Thursday, December 30, 2004 4:29 PM
Is the Castrol Super Clean hydraulic fluid ?- I have a problem to clean out a ships deck
which needs to be cleaned up. The white primer paint I used has bubbled (over previous coat of grey paint that did not come right !). I need to get rid of this bubbly primer. Is Castrol the only answer ? I am not sure that I will manage to find the Super Clean here in Malta.
Posted by Anonymous on Thursday, December 30, 2004 10:13 PM
For those who cannot get Castrol try thre Polly-S Easy-Lift-Off. it works well. One shot in the Dark may be Mechanics waterless hand soap, it is suppose to remove grease and oil and it just MIGHT work on models? Just a thought.
Posted by Anonymous on Monday, January 3, 2005 11:30 PM
the easy off is also available in a bottle somewhat like windex is, works great and easier to control at the same time, it took paint off of my revell X-1 in about an hour
