Meed Help with compressor choise!!!!
Posted by Anonymous on Wednesday, February 23, 2005 12:04 AM
Hi im new to the forum and sorta new to airbrushing. I have been looking for a airbrsh compressor for awhile. I want at least a small compact one to do some Art Designing on paper and mayber on the body. I have been looking on ebay and have found one for airbrushing use and only airbrushing. TESTORS / AZTEK AC300 and a badger oiless are some of them. THey seem to run at 20psi or so. Can anyone tewll me if thats an ok psi to run it at?
Posted by ABARNE on Wednesday, February 23, 2005 12:16 AM
20 PSI should be fine. I have a Badger 180, oiless I think, and it can get close to 30 PSI under load, but I never run it that high. My Badger 200 siphon feed, Aztek A430 side feed, and Paasche H siphon feed work well at 10 to 15 PSI.
Posted by Anonymous on Wednesday, February 23, 2005 12:20 AM
Thank you , cuase i was being told i needed alot of psi or so to run it or something. Anyone thing i should go with the TESTORS / AZTEK AC300?
Posted by Anonymous on Wednesday, February 23, 2005 2:36 AM
I think that the best advice is to buy the best compressor you can afford. Looking back, I should have purchased a compressor with an air tank attached and nice regulator. As for specifics, the pros will be in to help you out.
Posted by Anonymous on Wednesday, February 23, 2005 9:54 AM
welll i dunno which type of compressor to get lol
Posted by Anonymous on Wednesday, February 23, 2005 1:23 PM
What psi do i want is what im asking.
Posted by Anonymous on Wednesday, February 23, 2005 3:42 PM
Heya Talem,
Ok I'll stick to modleing to help you out. You will not need more then 25-30 psi MAx, most of your model ABing will be around 15-20 psi. 25-30 psi to clean with. With an oiless or diaphram compressor, often called a hobby compressor youll need a air regulator and moisture trap. You air will be coming to your AB directly from the compressor in really fast pulses. If you find that idea bad(I use a testors mini blue myself)then there are small hobby compressor that have a small tank installed with them. Aztek makes a decent one, top notch would be Badger millenium or an Iwata(media) comp.
Only thing the airtank does is give you a continious steady air. You take from the airtank and the compressor fills the airtank back up. In the long run the vast majority of modelers will use a tank equipped compressor.
Hope this helps you out and points you in the right direction,
Jeff
Posted by Anonymous on Wednesday, February 23, 2005 7:15 PM
hm ok man thank you , Iam no trying to get a Airmaster Plus which seems nice to just have a wide range of psi . I hope i get it.
Posted by Anonymous on Wednesday, February 23, 2005 11:39 PM
http://airbrush-depot.com/scripts/depot.exe?pgm=compress.bbx
get that, it has tank, regulator, moisture trap! pretty quiet too!
