tamiya thinners substitutes
Posted by Anonymous on Wednesday, February 23, 2005 8:52 AM
does any one know what i can use to thin tamiya acylics? I have been told by my local chemist that you cant buy rubbing alcahol now(i live in the uk). i have heard about car anti freeze and washer fluid but i'm not too sure. Help tamiya thinners costs a fortune when you are spraying a lot. thanks in advance and when the tiger is done there will be pics for all.Big Smile [:D]
    January 2004
Posted by MusicCity on Wednesday, February 23, 2005 6:40 PM
QUOTE: I have been told by my local chemist that you cant buy rubbing alcahol now(i live in the uk).
Why in the world not????? Did someone try to commit a murder with a bottle of alcohol?
You can try (as on some scrap to make sure it is going to do what you want) either water or auto washer fluid. You might also try the cheapest gin available. I've never tried that but it's mostly water and alcohol and should work OK.
    January 2005
Posted by STUG61 on Wednesday, February 23, 2005 10:20 PM
I'm surprised you can't get Iso. alchohol. I use the 91% over here. I also use distilled water and auto washer fluid. I've found part washer fluid and distilled water work well.The Iso alchohol works but it can speed drying and if your spraying a large amount at a time you may run into tip dry. I use the distilled water washer mixture cause our water here in Michigan has alot of minerals and it does effect the paint. I live in the country so our water isn't treated.My 2 cents [2c]
Smile! It makes people nervous!! Andy
Posted by Anonymous on Friday, February 25, 2005 10:27 AM
thanks, and i don't know why you can't get rubbing alcohol. Someone might have tried to drink it. Probably tastes better than the cheap gin though, Music city.
jeff
Posted by Anonymous on Sunday, February 27, 2005 12:29 AM
I am using IPA (ispropyl acholol) which is sold by chemical companies dealing in stuff like thinners, acetone etc. Problem is that they come in a large container and would you need to share with a few friends otherwise, it would last you years. As for the price, four 250ml bottles of Tamiya thinners can get you that one container.
Posted by Anonymous on Sunday, February 27, 2005 2:21 AM
Seriously, the UK has banned rubbing alcohol?
Next thing you will tell me, is that you can't use your AR-15 to shoot the tops off of ISO alcohol bottles.
You lot better well find some polititians who can nick a bit of common sense.
