MM Black and White
MM Black and White
Posted by Anonymous on Wednesday, February 23, 2005 7:54 PM
Maybe it's me, but do the Model Master flat black and flat white paints not cover anywhere near as good as their other colors? I've shaken up the bottle plenty, so that's not the problem, but I don't know what is. Can anyone help me? Thanks in advance.
    February 2005
Posted by MA Cooke on Wednesday, February 23, 2005 8:00 PM
First, stir the paint very thoroughly (use the handle end of a paintbrush), then stir some more, then shake. Some advise against this next step, but I put in 8 to 10 BB's, stainless steel BB's. Those help to mix more thoroughly, in my opinion.
Shaking alone is not enough. Even with the BB's, I stir first, then shake. James Bond would be outraged.
On Bench: AM P-51B, Tamiya 1/48 F4U-1A On Deck: Hasegawa F-14's (too many); Tamiya P-47D; Academy P-47N;
Posted by maddafinga on Wednesday, February 23, 2005 8:05 PM
I haven't had any problems with MM black, but the white is bad. I've switched to Floquil Reefer White and had no problems wth that. If you can get some I highly reccomend it.
Also, take full advantage of MA Cooke's advice, it's good and should be followed.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Wednesday, February 23, 2005 9:11 PM
I've seen a mini paint shaker on the net for around $25. May fix your problem. I thought about pruchasing this myself.
Posted by Anonymous on Thursday, February 24, 2005 12:52 AM
Thanks, I'll try that. By the way, where's a good place to buy cheap BB's? What is the exact science behind this anyway?
Posted by Delbert on Thursday, February 24, 2005 8:08 AM
If you have a dremal or like you already have a paint stirrer... get some of the q-tips with the long wooden sticks like you see in the doc's office... cut one off a bit longer than your bottle is deep... take a knife and whittle two sides of one end to make it flattened.. stick the round end in your dremal and the flat end in your bottle and turn on........
Posted by waikong on Thursday, February 24, 2005 8:38 AM
When you shake the paint with BB's the BB's breaksup the thicker pigments on the bottom. Just like spray paint (aka 'rattle' cans), the rattle is caused by a metal ball that helps mix the paint. Paints consist of basically pigment and a 'suspension liquid;' when you paint, the carrier helps you smooth the stuff on, and then evaporates leaving the pigment, which gives you the color and covering power. Don't mix the paint enough, all you get on top is mostly the suspension liquid.
Posted by djrost_2000 on Thursday, February 24, 2005 11:38 AM
Round toothpicks are also good for stirring paint.
-Dave
