Enamel thinner for acrylic paints?
Posted by Anonymous on Tuesday, June 21, 2005 11:30 PM
I'm making a wash for some of my armor models....
Can i use Model Master Airbrush Thinner (it says it's an enamel thinner) to thin my model master acrylic paints??
this is my first wash, so i'm just making sure i have all my steps coveredWink [;)]
thanks,
Baseball
    September 2004
Posted by giobosco on Wednesday, June 22, 2005 1:41 AM
Hi, I don't think it is a wise idea. Usually what I do is to apply a coat or two of Acrylic flat varnish to the part, let it/them dry and then apply a wash of enamel black (matt) at a ratio of 1 part paint to 9 parts of thinner (enamel thinner). Check this link out for further info. Model Master have their own acrylic thinners:
http://www.hobbylinc.com/htm/tes/tes50496.htm
Best regards
GB
    July 2004
Posted by tho9900 on Wednesday, June 22, 2005 5:54 AM
DoW - no, they definitely will not mix. You can use Isopropol alcohol (the clear stuff from Wal Mart etc... NOT rubbing alcohol) to thin that, or buy an acrylic thinner from Model Master or Tamiya at the local hobby shop or Hobby Lobby etc...
There's a good article on washing here:
http://www.swannysmodels.com/Weathering.html
    September 2004
Posted by Borg R3-MC0 on Wednesday, June 22, 2005 6:39 AM
DoW, enamel thinner and acrylic do not mix.
No really, they don't.
Enamels are oil based, acrylic water/alcohol based. Oil and water do not mix.
As tho9900 sugested, try alcohol as a thinner for acrylics.
Posted by Anonymous on Wednesday, June 22, 2005 11:07 AM
I agree regarding model master paints. I sometimes use lacquer thinner with some acrylic tamiya paints but it doesn't work with all colors for some reason. Tamiya paints are the exception in this case. Model master acrylics need an acrylic based reducer, either manufacturer thinner, distilled water, IPA, or a combo of those.
Posted by Anonymous on Wednesday, June 22, 2005 12:17 PM
would i just be able to use water????
i know MM paints are water clean up, and i'm looking at my paintbrush cleanup bowl.....it's about the color i needWink [;)]
    July 2004
Posted by Virago on Thursday, June 23, 2005 2:34 PM
I found that clear windex works great as a thinner for acrylic paints. It thins just like water, but dries a little faster because of the evaporation properties of the windex glass cleaner. I have not tries any of the coloured glass cleaners, I don't know what the effect it would have on the paint colour.
