to paint on the sprues or not to
Posted by Anonymous on Monday, June 27, 2005 6:14 PM
whats your thoughts?
Ive done both...
pros to painting on the sprues(cons to removing them)
easy to handle;
doesnt fly around;
stays organized
cons to painting them on the sprues(pros to removing them)
cant sand easily
connection points will need touchups after you remove them.
so what do you do? anything I missed?
Posted by Anonymous on Monday, June 27, 2005 6:19 PM
I find that for any small parts they are easier to paint on the spruce ie: handles, and roadwheels. The rest I paint on the kit.
    July 2003
Posted by Foster7155 on Monday, June 27, 2005 6:32 PM
I haven't painted parts on the sprues since...well...I guess since I was about 18 or so (1980)
Robert Foster
Pensacola Modeleers
    January 2004
Posted by MusicCity on Monday, June 27, 2005 8:59 PM
I agree with Robert. I never paint anything on the sprue because the vast bulk of the paint is going to get sanded off.
Posted by ABARNE on Monday, June 27, 2005 9:11 PM
I do tank road wheels on the sprue, very little else. What I will sometimes do tack little parts onto a piece of plastic with super-glue after I've done all the sanding, tacking on the areas that will be hidden by the glue joint when finally assembled.
Posted by Anonymous on Monday, June 27, 2005 9:37 PM
Nothing on the sprue for me not even roadwheels for all the reasons mentioned so far. Painting everything twice is double work. I use upside-down masking tape after I clean all the parts up. Paint one side, let em dry a little, flip everything, and paint the other side. hit all the attachment points with liquid mask beforehand too.
Posted by Anonymous on Tuesday, June 28, 2005 12:30 AM
I agree. I have never painted anything on the spures.
Posted by Anonymous on Tuesday, June 28, 2005 12:41 AM
I leave some of the small parts with small attachment points on the sprues, but only sometimes. I usually use a piece of styrene rod as a handle and glue the part temporarily. Works well for me.
    September 2004
Posted by Borg R3-MC0 on Tuesday, June 28, 2005 3:45 AM
I used to paint on the sprues, but as said by others, then you need to repaint after attaching.
Nowadays I use all sorts of clamps, toothpicks and tape to hold the object that I am painting.
    July 2003
Posted by KJ200 on Tuesday, June 28, 2005 8:13 AM
I usually drill little holes where they won;t be seen on the finished article and super glue a tooth pick in.
I've just done all the road wheels, return rollers, driver spockets, bogies.....well just about everything in this manner on an Italeri Semovente SPG.
It can seem an extra chore, but it is well worth while.
Karl
