RE: Priming my model
    June 2005
Posted by Pukindog on Thursday, July 7, 2005 8:30 PM
Hi Everyone,
I was wondering, When it comes time to prime my model, what would be the right color primer to use? Someone on another forum told me that I don't have to prime under a enamel finish, but I am worried that the finish color will turn out to dark. The color of the plastic is a dark gray, and I will be painting the model in Blue Angel blue finish. Any help greatly appreciated.
Thank you,
Evolution
    January 2004
Posted by MusicCity on Thursday, July 7, 2005 9:48 PM
You don't "Have" to prime before painting, even with enamel, but I prefer to. Priming allows me to see flaws that I'd otherwise miss and fix them before I put a lot of effort into a final paint job.
A light primer will sometimes make the final coat slightly lighter while a dark primer will sometimes make it slightly darker. If the paint is truly opaque this is usually not a big problem. For the Blues I'd probably use something like a medium gray color.
Posted by Anonymous on Friday, July 8, 2005 7:13 AM
/quote]
Thumbs Up [tup] Thumbs Up [tup] Thumbs Up [tup]
Posted by Anonymous on Saturday, July 9, 2005 1:38 PM
how does that work? I always wondered; I always prime; but never see the flaws after paint that i didnt see before. most any primer Ive seen is very flat; so you cant see distortion in the reflection. so what is it your looking for in the primer?
    July 2004
Posted by tho9900 on Saturday, July 9, 2005 2:22 PM
ares - small gaps or cracks in the seam line missed while puttying and sanding show up like a sore thumb! Also uneven sanding of the leading edges on the wings and such stand out too.
Posted by Anonymous on Saturday, July 9, 2005 5:05 PM
I like to do spot priming with MM enamel Light Ghost Gray. It doesn't dry purely flat and works great for making sure you have a smooth surface where you did bodywork.
Posted by Anonymous on Saturday, July 9, 2005 6:37 PM
Would that MM light Ghost Gray also work as a primer before using Acrylic paints?? Im also concerned about paint adhesion to the styrne plastic and heard that enamel bonds better to plastic.
Posted by Anonymous on Sunday, July 10, 2005 12:09 AM
ohh got it. thatd explain it; untill my next model I always did cars and never used putty. cars are 1 peice on the body atleast; so priming it doesnt really show much.
you guys have made me want to be a better builder though; good to know about the primer. itll come in handy for my warthog and putty thats arriving on monday :) so exciting.
    July 2004
Posted by tho9900 on Sunday, July 10, 2005 7:37 AM
Claude - it would work somewhat, but the primer does have a better surface for the paint to adhere to. You can even use the Krylon primer found at WalMart if you want. At about $4 for a huge can it's a bargain! The auto primers come in different grades and you can get them at Auto Zones and Pep Boys etc... Tamiya makes a spray can version of their primer as well.
Ares - good luck to you! I've been able to spot things not visible before primering and it's helped make my end results look better!
