Polly Scale Flat Clear
Posted by Anonymous on Saturday, July 9, 2005 4:50 PM
After hearing good reports about this stuff I finally got hold of some.
Before using it on my newly finished model I tested it on my test model.
The trouble is that it dried with a slightly milky finish.
Has anyone come across this?
    January 2004
Posted by MusicCity on Saturday, July 9, 2005 5:18 PM
The only time I've had that happen with any acrylic clear flat was when I got it on way too heavy. Thin coat, let dry, thin coat, let dry. Two coats is usually enough for me.
Posted by Anonymous on Saturday, July 9, 2005 5:30 PM
Thanks Music that's probably it because I sort of slopped it on with a brush.
    January 2004
Posted by MusicCity on Saturday, July 9, 2005 6:41 PM
I suspect that's what caused it then. It may clear up over time. Sometimes when paint is put on real heavy like that it takes a good while for it to completely cure.
    February 2005
Posted by MA Cooke on Sunday, July 10, 2005 9:24 AM
Related question: what do you use to thin & clean the
Polly S flat?
On Bench: AM P-51B, Tamiya 1/48 F4U-1A On Deck: Hasegawa F-14's (too many); Tamiya P-47D; Academy P-47N;
    January 2004
Posted by MusicCity on Sunday, July 10, 2005 10:41 AM
I don't thin it. It sprays fine from the bottle.
The label says use water for cleanup and that seems to work fine. I've also used Windex, alcohol, laquer thinner, mineral spirits, whatever I happen to have sitting close to hand.
    February 2005
Posted by MA Cooke on Sunday, July 10, 2005 11:17 AM
"...whatever I happen to have sitting close to hand."
Scott, I hope you don't take that approach with your contact lenses! Laugh [(-D]
(I don't actually know if you wear contacts, I just had to jump on that opportunity.)
