How to remove paint from canopies treated w/ future
Posted by Anonymous on Sunday, July 17, 2005 10:55 PM
The paint sneaked under the mask on the canopies of two of my kits. Since I dipped them into Future, it should be easy to get rid of them. The question is how? I tried alcohol, Publix Window cleaner with ammonia, butthey're a pain in the neck, and don't really work.
Some advice would be appreciated.
Thank you.
    September 2004
Posted by giobosco on Monday, July 18, 2005 5:16 AM
Hi There, this maybe a long shot but what about some tamiya polishing compund rubbed on with a cutex or ear-bud whatever you want to call it?? You will probably lose some paint on the framing, but that can be touched up later. I have tried this and it worked for me, I actually had super glue on the canopy. So basically, rub them down, which should restore them to their original transperent selves, then re-future them, and touch up with a final coat of future to seal the whole lot.
Hope this helps
regards
Gb
Posted by Anonymous on Monday, July 18, 2005 9:57 AM
Thanks for the reply. I would rather dissolve the Future with something. It's less harsh and this is one of the points of using future anyway. I just don't know with what.
(But I really appreciate your answer. I might need some canopy touch-up in the future...) :)
    June 2003
Posted by Duke Maddog on Monday, July 18, 2005 11:15 AM
I use a sharpened popsicle stick to scrape off the paint from areas of the canopy that are supposed to remain clear. It is sharp enough to scrape the paint, yet soft enough not to scratch the canopy, particularly if it is coated in Future. If it does scratch the canopy, the scratch is usually shallow enough that a new dip in the Future will eliminate it.
    July 2004
Posted by tho9900 on Monday, July 18, 2005 7:13 PM
if it is not a huge area of paint a toothpick works well too... just use the tip to scrape and push the paint toward the frames.. as Duke said, future will take care of most scratches if any arise...
    January 2004
Posted by MusicCity on Monday, July 18, 2005 8:14 PM
If you want to take it all off Castrol Super Clean will do it. Haven't tried it on clear parts though so I'd advise trying it on some scrap first. You can find it at Walmart or most auto supply stores.
    March 2005
Posted by Jeebus on Tuesday, July 19, 2005 12:13 AM
hmm! i USE TOOTHPICKS FOR THE SAME THING.Big Smile [:D]
