proper airbrush cleaning
    May 2004
Posted by modelbuilder on Sunday, July 24, 2005 8:34 PM
Hi all, I use a Modelmaster Aztec nozzle system airbrush. After each use I spray a generous amount of airbrush thinner through it but still get the occassional clogged nozzle. Is there anything I can do to help prevent this? Is there a specific airbrush cleaner I should use?
Posted by Anonymous on Sunday, July 24, 2005 8:45 PM
I use lacquer thinner, about half a jar, half way threw, I put a piece of kitchen paper over the nozel to help shift paint from that area, so far no problems with blockages
Posted by ABARNE on Monday, July 25, 2005 2:13 PM
I know some of the regular Aztek users also recommend soaking the nozzles in thinner. For more drastic action, you can also pull them apart.
    July 2004
Posted by tho9900 on Monday, July 25, 2005 6:37 PM
back when I had my Aztek I found the soaking overnight in the appropriate thinner helped a LOT! I had a lot less problem with clogging...
Posted by genj53john on Monday, July 25, 2005 8:00 PM
Common Aztec problem because yoy can't really take the tips apart a clean them although I tried when I was using it. I don't recommend it. Their never go back together right. Soaking in an airbrush cleaner seems to help.
John
