Stripping MM Acrylics
Posted by Anonymous on Saturday, July 30, 2005 11:34 AM
What is the best way to strip MM Acrylics without stripping the MM enamels underneath? I tried rubbing alcohol which worked to a point, but not very well. It turned the glossy clearcoat flat and white like superglue fog. This would look good on some jet engine parts though. A nice white ash that is controllable where you want it.
    July 2004
Posted by tho9900 on Saturday, July 30, 2005 2:45 PM
hmmm I wouldnt know how to do it without stripping the enamel too... maybe someone else could come along and help you out... two things I can think of would be either windex or MM Acryl dried paint remover (it's not a solvent that will harm enamel)
good luck and maybe someone with more experience in what you are trying to do will come along... usually I just strip everything...
Posted by MikeV on Saturday, July 30, 2005 4:56 PM
Try a little Windex or Simple Green and see if it works.
Posted by mass tactical on Saturday, July 30, 2005 5:29 PM
If the acrylic is cured both enamel and acrylic will come off together no matter what you do. If the acrylic is very fresh you might try Simple Green or 409. Even then it's a long shot because of the way acrylic sets up.
Mike M
