Painting over metalizer sealer.
Posted by Anonymous on Tuesday, August 9, 2005 11:38 PM
Does anyone know if you can paint Testor Model Master Metalizer down, buff it, seal it with the recommended sealer, then paint over it?
    June 2005
Posted by MontanaCowboy on Wednesday, August 10, 2005 12:51 AM
As long as you let it cure, it should be fine. I'm 99 percent sure you can also mask over it.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    May 2003
Posted by qmiester on Thursday, August 11, 2005 10:21 AM
I think I would do some experimenting before I tried it on something I really didn't want to screw up - Take an old model, apply metalizer and let dry, apply the seal and let dry and then apply tape and see what happens when you remove the tape - My thinking is that the seal coat would just act as a coat of paint - if you taped it, it would hold to the metalizer but the metalizer would still peel when you tried to remove the tape.
Quincy
    June 2005
Posted by MontanaCowboy on Thursday, August 11, 2005 12:28 PM
Maybe really low tac tape would work if regular doesn't. But then you risk paint getting under the tape.
