I hate canopies...
I hate canopies...
Posted by Anonymous on Thursday, September 1, 2005 8:23 AM
...and they hate me.
My canopies (or any clear part that has painted bits on it) are an endless struggle for me. It's a cycle of paint, drip/slip, clean, paint... I know it can be done, most of the ones you guys do I'd swear that the canopies and the cross braces are separate parts, that's how perfect they are.
What's the secret? A certain way of masking? single hair brushes? pixie dust??
    January 2004
Posted by MusicCity on Thursday, September 1, 2005 9:08 AM
QUOTE: What's the secret? A certain way of masking? single hair brushes? pixie dust??
For me it's Tamiya masking tape (always and only Tamiya masking tape), a brand new and very sharp X-Acto blade, an airbrush, and a lot of time masking and trimming. It's never failed me yet.
Posted by Anonymous on Thursday, September 1, 2005 10:21 AM
really now? What's Tamiya have over your basic masking tape? I mean, I trust you and it's already on my shopping list, but I just don't know.
Also - you break out the AB even for canopies, huh? The big guns...well that cinches it, I gotta get one now.
    January 2004
Posted by MusicCity on Thursday, September 1, 2005 11:18 AM
QUOTE: really now? What's Tamiya have over your basic masking tape? I mean, I trust you and it's already on my shopping list, but I just don't know.
I trust it because it has never failed for me. There are probably some tapes that are just as good and cost a little less, but I have never had a problem when using Tamiya tape. It's thin so it goes around curves a little bit better. It's relatively low-tack but at the same time seals very well. Burnish it down with a fingernail or toothpick and it just plain won't leak.
QUOTE: Also - you break out the AB even for canopies, huh? The big guns...well that cinches it, I gotta get one now.
I'll use an airbrush for a single small part if necessary. About the only thing I don't airbrush are cockpit details such as instruments and other tiny details.
I used to hate canopies
Posted by Anonymous on Thursday, September 1, 2005 11:47 AM
I'm too cheap to buy Tamiya tape. I use good old Scotch tape, the dull looking one as opposed to the shinny one. I then use a blade from an old disposable razor to cut. My first few canopies were a painful process but now its not so bad. For example I can do a 1/32 scale Bf109 canopy in about 1/2 hour. Using an airbrush is also a must to lay a thin layer of paint so that it minimizes the runs underneath.
The only caveat with Scotch tape is that it sticks to the canopy too well so taking it off is tricky.
Posted by Anonymous on Thursday, September 1, 2005 12:32 PM
So...I assume the tamiya tape isn't all you use to mask then, right? Other wise I assume you'd get overspray? Do you just tape some paper or something over/beyond your precision mask at that point?
    January 2004
Posted by MusicCity on Thursday, September 1, 2005 2:09 PM
QUOTE: So...I assume the tamiya tape isn't all you use to mask then, right? Other wise I assume you'd get overspray? Do you just tape some paper or something over/beyond your precision mask at that point?
Nope, pretty much just Tamiya tape. The way I mask them is similar to Swanny's method on this page:
http://www.swannysmodels.com/Canopies.html
but I don't dip them in Future first.
Posted by Anonymous on Thursday, September 1, 2005 7:37 PM
How about Maskol???????????
Posted by Anonymous on Thursday, September 1, 2005 8:38 PM
Maskol is widely used for canopies but often just to fill in the centre of panels, the actual edge to the framing being masked with yep Tamiya tape! Scott has put you on the right track there and like him I use no other type of tape. If you try to paint the maskol on with a paintbrush and then spray the framing your edge will still only be as straight as your ability to brush paint - not what you are wanting. As you wlll no doubt have gathered there are many masking mediums that can be used and each have their uses in different situations. Experiment, use the advice that people offer here and find what works best for you.
One last thing - you can't get better than Tamiya tape - Oh I said that already.Wink [;)]
    July 2004
Posted by tho9900 on Thursday, September 1, 2005 8:50 PM
I've used Model Master tape with great results, as well as Tamiya tape and Bare Metal Foil (a bit expensive but it gives the best results)
The leader based on price and outcome? you guessed it... Tamiya tape... it gets around the curved braces on the canopy like a champ and doesn't cost near as much as BMF.
On a side note though I have run across canopies that HAD to be done in Bare Metal Foil as the brace lines were recessed and many and BMF will fit itself into the smallest groove...
for your standard canopy though, it is Tamiya all the way!
    August 2003
Posted by tweety1 on Friday, September 2, 2005 9:39 AM
I used to use Tamiya tape and Maskol all the time, till I stumbled onto BMF masking, and now Foil is all I use.
I find it to be excellent adhesion, great for curves, has absolutely no bleed under, and leaves a crisp paint line after removal.
Yes it is a little high in price, but I have used barely 1/8th of a sheet, and have done 12 models with it.
Mind you I only use Foil for canopies, and Tamiya tape for everything else.
It really is a case of trying it out for yourself, like most things in modeling.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    May 2005
Posted by Bgrigg on Friday, September 2, 2005 10:06 AM
Build WWI aircraft, no canopies! Big Smile [:D]
So long folks!
Posted by Anonymous on Saturday, September 3, 2005 6:11 PM
Hehhahaha, Winnar!
    February 2004
Posted by RichardI on Saturday, September 3, 2005 6:22 PM
pseudodigm: I'm with you. I use EZ-masks and they are great. Even a stumblebum like me can get first rate results using these - even the first time I tried them.
http://www.ezmasks.com/index.html
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
Posted by Anonymous on Saturday, September 3, 2005 9:53 PM
Me too... I just lost the canopy for my 1/48 Corsair I spent 1 year building. :(
    January 2004
Posted by knight667 on Tuesday, September 6, 2005 4:51 PM
I "cheat" and use precut Black Magic masks whenever I can. I figure the expense ($5-8 per set) is worth the saved time, energy, blood, sweat, tears (oh yes, there have been those) and thrown parts. When I can't get them, I use strips of masking tape and use Swanny's method:
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
