Model Master Acrylics
Posted by Anonymous on Thursday, September 22, 2005 12:24 AM
Does anyone else find Model Master Acrylics to be a little more difficult to spray than Polly Scale or Tamiya? Tonite was one of those nights I couldn't get it right.
E
Posted by mass tactical on Thursday, September 22, 2005 9:30 AM
I have had good luck when thinning with Acryl Thinner which is a Model Master product. I usually add just a couple of drops and it helps paint flow. Most acrylics are problem prone due to their quick drying times. Before I spary them, I always shoot a little thinner through my airbrush. A little needle lube can also be of benefit. Keeping your airbrush spotless, with particular attention given to the nozzle and needle , will help.
Mike M
Posted by Anonymous on Thursday, September 22, 2005 11:37 AM
Did all of the above ( except for spraying thinner before the color ) , just one of those nites I guess. Thanks.
E
Posted by Jeeves on Thursday, September 22, 2005 12:48 PM
Pick up some acrylic retarder at any craft shop-- a few drops before you add your paint prevents buildup as it lengthens the dry time a bit...
    January 2004
Posted by MusicCity on Thursday, September 22, 2005 5:25 PM
I use MM Acryl, Tamiya, and PollyScale a lot and don't see much difference in how they spray. PollyScale is a lot thinner than the other two and doesn't need to be thinned any more, but they all three spray great.
Posted by Anonymous on Thursday, September 22, 2005 7:52 PM
Make sure you don't over thn Model Master Acryl paints. Some of them you airbrush without thinner or only using a few drops of thinner. Remember, you want the consistency of milk.
Jesse
    September 2003
Posted by dragonfly on Saturday, September 24, 2005 6:04 PM
It's all about the thinner, get it right and you'll have no problems.
Jerry
Posted by Anonymous on Saturday, September 24, 2005 9:45 PM
Thanks guys. I put thinner and retarder in that batch of paint the other night but I guess the ratios were not what they should have been. Seems that enamels are a lot more forgiving than acrylics. I was telling SWMBO that I have never been able to spray acrylics well even as a teenager, although I did manage to write her name with the Anthem and the 150. As a side note, I was thinking of selling my Crescendo, but it does lay down acrylic as a base coat like a pro. So I guess I'll keep it. So thanks again and I'll jump back on the acrylic horse and ride it with PollyScale.
E
... now what will I do with that big can of Model Master enamel thinner I bought at the LHS tonite?????
