BADGER QUESTION.....HELP?
Posted by Anonymous on Monday, July 14, 2003 9:50 AM
i use a badger 200nh and when i go too spray instead of giving me a smooth stream of paint it just spits it or i get a spattering efect ,i replaced the tflon piece inside ,could some one help me out with some airbrush knowledge,and by the way its been clean so i know its not dirty.....
Posted by Ray Marotta on Monday, July 14, 2003 10:53 AM
Sounds to me like your paint may not be thinned enough. It should be about
the same consistancy as milk. I have a Badger 200 and when it spits paint,
a little more thinner in the mix almost always fixes the problem.
Ray
Posted by Anonymous on Monday, July 14, 2003 10:56 AM
it does it with just pure alcohal
Posted by berny13 on Monday, July 14, 2003 11:50 AM
What type of compressor are you using? Do you have a moisture trap? Incorrect pressure or moisture can cause the problem you are having. Try to lower the pressure and see if the problem goes away. Clean the moisture trap. Experiment with different pressures. Try to eliminate one cause at a time.
Berny
 Phormer Phantom Phixer
On the bench
Posted by rossjr on Tuesday, July 15, 2003 11:01 AM
From my experience the sputters tend to come from either something caught in the brush, like cotton from a Q-Tip, a dirty brush or a poor seal. The spurts or splatters tend to be created because something blocks the airflow and not enough air is allowed to pass for the syphon affect. Presure then builds and releases send the paint splat and then the process repeats. Make sure all your parts are assembled correctly and tightly, if they are you may want to disassemble the brush and give it a complete cleaning.
How do you clean your brush when you are finished using it after each use?
Posted by Anonymous on Tuesday, July 15, 2003 12:18 PM
Lastnight i took everything apart and let it soaked in lacquer thinner havent tried it yet its still soaking ,could a bent needle cause the problem ?
Posted by rossjr on Tuesday, July 15, 2003 1:02 PM
It is possible, you might want to becareful with the lacquer thinner too. It has a nasty habit of (over long exposure) deteriorating the seals in the airbrush. Some are easy to replace, but one located in the back of the body is factory only replacement.
As long as you get everything back together again and have the seals on tightly, I would think it would take care of it.
