Which Iwata
    July 2005
Which Iwata
Posted by cawashbu on Friday, November 18, 2005 6:40 PM
I will be heading to Japan soon and I was thinking about buying an Iwata.  My question is which one?  I have an Aztek I use for basic stuff, so I am looking for a brush that will allow me to do finer detail work, and ideally I would like to be able to change some parts and use it for medium covearge too if possible.  Any thoughts?  Also, anyone know of a good place in Japan to shop near Tokyo?
    July 2004
Posted by tho9900 on Friday, November 18, 2005 7:04 PM
The HP-CR is a good all around as well as detail brush and sprays acrylics well.  It is even modestly priced! It has one needle/nozzle combo so no need for extra parts.
The HP-CS is good at medium to fine work and also does well although I know at least one person who ended up buying an HP-CR for acrylics and using the CS for everything else.  The HP-CS has a .35mm nozzle/needle combo but now you can buy the .5mm needle and nozzle, it came out recently I understand.  So I guess the issue of acrylics would become moot if you chose that one with the extra gear.
I own the HP-CR and love it, fantastic brush and can do some outstanding fine work, even at my limited level of experience with it right now.
It is perfect for anything 1/48 aircraft or even 1/32.
Good luck!
    August 2003
Posted by tweety1 on Sunday, November 20, 2005 1:24 AM
I own a HP-BS and love it!
It does some great detail spraying with acrylics and the .35 tip, and the trigger is so smooth, the atomiztion is fantastic.
I also got the pre set handle with mine, and a set of quick connects and the crown cap.
Definately worth every cent
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    July 2005
Posted by cawashbu on Sunday, November 20, 2005 9:49 AM
I will use MM enamals, I have not made the switch to acrylics.  Will that effect which one I should choose?
    February 2004
Posted by RichardI on Sunday, November 20, 2005 5:20 PM
Nope. Smile [:)] Won't make any difference. I own 2 Iwata's and they both spray every medium I have tried in them.
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
Posted by MikeV on Sunday, November 20, 2005 6:02 PM
Iwata? Is that a new car? lol
Posted by Torio on Monday, November 21, 2005 11:34 AM
Well, chap, I suppose you expect to find Iwata airbrushes at lower price there; if such is the case, I suggest you also buy an extra nozzle, two extra needles and a set of washers ( if you wnat to use several gauges on your airbrush, I suggest an extra nozzle and two extra nozzles per gauge, well, look at your budget anyway )
Mike, "leave them kids alone", don't try to badgerize him if he wants an Iwata, he'll have time in his life to get a Badger too
Thank you all for coming José
Posted by Gageiro on Monday, November 21, 2005 1:47 PM
I´m going to Japan next Thursday Nov. 24, and I also want to buy an Iwata. The model I choose was HP C.
Have you got any answer about the place to buy?
In Akihabara (Tokyo) there aresome hobby shops. I hope they carry this item.
When I come back I tell you what I have found.
    March 2005
Posted by yah4sure on Monday, November 21, 2005 2:47 PM
I have been an airbrush illustrator since the early 80's. I
worked mostly with guaches, but recently revisited model
making and used my HP-C with enamels and found it
good for a variety of applications. You can get as tight as
sewing thread width or use it for large areas. Get a crown
nozzle and a couple extra nibs and needles. I like the large
gravity feed cup has a cap so you're not sloshing paint all
over your work.
Here's a look at the one I'm talking about.
http://www.arttalk.com/iwata/hp-c.htm
Good luck!
    July 2005
Posted by cawashbu on Monday, November 21, 2005 5:18 PM
I am leaving Dec 3rd.  I will spend a night in Tokyo and then head west to Toyama for a week.  Hopefully I can find a shop that sells Iwata.
