what's the best way to achieve the flat paint look
Posted by Anonymous on Sunday, July 27, 2003 10:26 AM
I'm using enamel paint. (aircraft gray) it doesn't say on the bottle that it is a gloss finish, but after my first spray, it has a pretty glossy look to it. I dunno if i didn't put enough thinner in it, or if i sprayed too much paint at one time or if its something else. Any suggestions? thanks in advance.
    June 2003
Posted by allan on Sunday, July 27, 2003 10:40 AM
I suppose having that glossy finish in fact gives you more benefits. That way the decals will cling to the surface better. You can thereafter spray the model with a flat coat.
Gloss paints will usually result in a glossy (or at least semi-gloss) finish regardless of the amount of thinner you put in. If you want to spray on a flat finish right away, you can add a flat base, if one is available in the brand youre using, and mix the same to the paint before spraying. Be careful, though, as too much flat base will give you a "snowed" finish (apparently, the dissolved flat base re-crystalizes after drying and leaves white-colored accumulations). Try spraying the mixture on a old model first and see how it dries up.
Hope this helps.
No bucks, no Buck Rogers
Posted by Anonymous on Sunday, July 27, 2003 10:43 AM
I think enamel paints are always gloss unless it states on the bottle that it is flat. To acquire the flat look just spray it with a clear flat coat (after applying decals of course)
Jack
    May 2003
Posted by styrene on Monday, July 28, 2003 6:56 AM
Try looking closely at the paint bottle before you buy. For FS (Federal Standard) colors, the first number will tell you flat, gloss, or satin:
17875=Gloss white
27875=Satin white
37875=Flat white
Hope this helps a little.
Gip Winecoff
Posted by Anonymous on Monday, July 28, 2003 8:14 AM
NAPTHA...The stuff you put in zippo lighters. will matt gloss paints..add a few drops to your mix..test spray ..not flat enough add more drops...test spray...till you get the finish you want[ test on scrap] this also works with matt paints that are a bit old and tend to lean towards the semi gloss.....
Posted by kaleu on Monday, July 28, 2003 4:56 PM
I use Dullcote to get a matte finish and to seal and protect the paint.
Erik "Don't fruit the beer." Newest model buys: More than I care to think about. It's time for a support group.
