Sputtering
Sputtering
Posted by Anonymous on Wednesday, December 28, 2005 11:34 PM
I have only been using my airbrush for a short while and I keep having a problem with it. I have a Paasche H set and I use Tamiya acrylics. Whenever I am painting as soon as I hit the trigger the paint comes out but usually with a sputter of something, im not sure if this is paint or water but it really wrecks a paint job. I have a Paasche moisture trap and I have made sure to stir my paint but I still have this problem. Thanks in advance for any help.
    May 2005
Posted by Bgrigg on Wednesday, December 28, 2005 11:39 PM
Are you thinning your paints? Acrylics might seem thin enough, but they're not! See MusicCity's article on thinning paints.
Acrylics also dry really fast, so keep a moistened Qtip handy to swab out the tip (pulling back the needle and not using air, of course!).
Check out the rest of MusicCity's website, some very useful advice there!
So long folks!
Posted by Anonymous on Thursday, December 29, 2005 1:29 AM
I think it is probebly the tinning, Im not very good at thinning paint, I usully put to much in and then i get a watery mess, so I have been under thinning my paint. I could use some ips on how to measure and mix paint properly.
    May 2005
Posted by Bgrigg on Thursday, December 29, 2005 9:16 AM
Some people use pipettes. then either measure drop by drop or they get calibrated pipettes. I bought some, but only use them for transferring thinners and squirting Windex into the colour cup when cleaning.
What you should be looking for is the consistency of milk. I measure by eye until I get that consistency. Which doesn't sound very consistent, does it? Wink [;)]
Let's back up for a second, though. What do you use for an air source? Do you have a regulator? I find controlling the air pressure is far more important then exact thinning ratios. You can spray some very watery paint quite well if you can control the pressure. See MusicCity's article on air pressure.
I use a dual action AB for my main painting, but have a cheap clone of the Badger 350 single action that I use for laying down my clear coats. It's basically the same kind of AB the Paasche is. Since I've only squirted Future through it, I don't have any real experience of how to paint with one.
So long folks!
Posted by Anonymous on Thursday, December 29, 2005 3:46 PM
My air soure is a compresor with a regulator, I usually use around 20 psi to paint with. I also looked at MusicCity's article and it says that external mix airbrushes (like most single action ones) require more air preassure to atomize paint. Im also going to see if I can find some of those pipettes to transfer my thinner so I can get a more controlled amount.
    May 2005
Posted by Bgrigg on Thursday, December 29, 2005 4:18 PM
See if you can find a medical supplies place (I'm sure there must be one in Vancouver!) as the model shop ones are just too darned expensive!
One method I've used to transfer paint is a plain drinking straw. Stick one end in the paint, put your finger over the other end and transfer the paint that way. Problem with this method is you get less and less paint as the level in the jar drops...
So long folks!
Posted by MikeV on Friday, December 30, 2005 3:18 AM
Just go to the drugstore and buy a few glass eyedroppers, they are cheap and work great. Wink [;)]
    May 2005
Posted by Bgrigg on Friday, December 30, 2005 10:24 AM
I just remembered that the syringes used to measure pet medicine or plant food also work great!
So long folks!
    December 2003
Posted by thevinman on Friday, December 30, 2005 1:04 PM
You can get those plastic disposable pippetes off ebay for really cheap.
Posted by Anonymous on Saturday, December 31, 2005 9:48 PM
I found out why I had drops of paint all over my model, and its the dumbest but easist to fix reason ever.
My AB is a single action EXTERNAL MIX brush so whenever I had it tiped and angled down paint from the colour cup would drip down and out of the paint tip. I easily fixed this by having the AB at a horizontal level and after hitting the trigger I pointed it down.
However I did love the tips about measureing paint, I got a glass syringe that allows me to get just the right amout every time and my paint coats look a lot better.
    May 2005
Posted by Bgrigg on Saturday, December 31, 2005 10:41 PM
Put a piece of masking tape over the colour cup. That eliminates accidental spills.
So long folks!
Posted by Anonymous on Saturday, December 31, 2005 11:45 PM
Its not quite like that,
When I had the Airbrush at a high angle with no air on, if I had the paint tip open wide enough the paint would sinply drip out of the paint tip from gravity, as seen here.
I hope this makes sense im not good at explaining things.
    May 2005
Posted by Bgrigg on Sunday, January 1, 2006 1:16 AM
Ah, makes perfect sense, pictures truly are worth a thousand words.
So long folks!
Posted by Anonymous on Sunday, January 1, 2006 2:42 AM
I wish, I could write a 5000 word essay in 60 seconds.
    January 2004
Posted by MusicCity on Sunday, January 1, 2006 7:01 AM
You can!  Select All, Cut, Paste, change Author's name, Print.
    May 2005
Posted by Bgrigg on Sunday, January 1, 2006 10:52 AM
Scott, you've released the Secret of Print Journalism! LOL!!
So long folks!
    July 2004
Posted by tho9900 on Sunday, January 1, 2006 5:36 PM
and many high school students as well!  My sister is a teacher and has caught a few at it... some of them aren't that smart though.. they print out the web page,  and glue on a piece of paper with THEIR name on it, over the authors name... then they Xerox it...
Too bad they forget that when you print from the web the URL is at the bottom of the page...   Disapprove [V]
