Micro Scale Flat
    November 2003
Micro Scale Flat
Posted by JoeRugby on Monday, February 20, 2006 9:53 PM
Has any one used this?  Looking for some feedback..
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
Posted by Anonymous on Tuesday, February 21, 2006 10:44 AM
i've used it.  it's not actually flat.  it's still glossy.  barely satin.
Posted by ABARNE on Thursday, February 23, 2006 1:43 PM
I've used it with similar results to those of GoatMonkey.  It was somewhat duller than semi-gloss, but a far cry from flat.  I did brush paint it, and I'm not sure what effect that would have on the glossiness.  I did find a nice use for it by using it as a binder with pastel chalk dust to make a reasonably decent mud for a Sherman tank.
Andy
    January 2003
Posted by Jeff Herne on Thursday, February 23, 2006 4:17 PM
I use the flat for semi-glossing...
Trod on down to the local supermarket and buy a bottle of Future, then hop on over to your local hobby shop and buy a couple of bottles of Tamiya X-21 flat base.
Mix the two together, I generally start at a 4:1 ratio of Future to X-21.
Once you find that ratio that you're looking for, mix up a big batch (for consistency's sake), and spray away.
Gloss coat the model before decaling with regular Future.
This way, you're not applying dis-similar flat coats over each other, and you're less likely to get reactive results.
Jeff
    May 2003
Posted by qmiester on Saturday, February 25, 2006 9:58 AM
I used the Micro clear coatings for years until I noticed that they were yellowing faster than some of the other clear coats I was using  (Dull and Gloss Coat, Walthers DDV etc.  So I quit using them, preferring Future for gloss and MM Semi-gloss and Dullcoat and DDV for flats.  Actually, the yellowing doesn't show up that badly except on white colors - kinda makes the model looks dingy - or that it needs to be dusted or washed, neither of which makes any difference in the appearance.  Has anyone noticed any yellowing problems with acrylics?
Quincy
