Electric Cordless compressor
Posted by Anonymous on Monday, August 4, 2003 3:20 PM
http://www.walmart.com/catalog/product.gsp?cat=4091&dept=5428&product_id=3992&path=0%3A5428%3A51199%3A4093%3A3915%3A4338
Is it a good deal?Eight Ball [8]Sleepy [|)]
Posted by Anonymous on Monday, August 4, 2003 5:28 PM
dadfad
That might be a good deal.
But it's NOT for airbrush use.
Posted by Anonymous on Monday, August 4, 2003 6:14 PM
it isnt?
    January 2003
Posted by shermanfreak on Monday, August 4, 2003 8:49 PM
Chances are it wouldn't be good enough for airbrush use. What you need is something that can give a controlled, constant pressure. Also the connector that is on this unit is a little awkward to adapt to airbrush use. Look for a larger unit that has a regulator on it .... they are available in the U.S. at Walmart and are also made by Campbell Hausfeld.
Posted by Anonymous on Monday, August 4, 2003 9:54 PM
Well, see, im a little short on cash right now, and i would jump at the chance for a cheap air compressor. Do you know of any good compressors for a good price?
Posted by MikeV on Monday, August 4, 2003 9:55 PM
That is made for filling up your cars tires not airbrushing. Big Smile [:D]
    January 2003
Posted by Keyworth on Monday, August 4, 2003 10:18 PM
That thing is noisy, has very erratic psi levels, and can't be effectively regulated. Besides the fact that it dances all over the floor, it's just not what you need.
"There's no problem that can't be solved with a suitable application of high explosives"
    January 2003
Posted by shermanfreak on Monday, August 4, 2003 11:55 PM
One something like this may suit your purposes a little better. Not only for using with an airbrush, but you can tell the wife that you can do all kinds of things around the house too. This unit lists for $109 but I'm sure you can get one like it for less.
Posted by MikeV on Tuesday, August 5, 2003 7:17 AM
Shermanfreak,
That little compressor is affectionately known as "Junior" over on the airbrush forum I visit. The consensus on that unit is that it works good if you don't use it for long periods of time. Most people who have bought them for airbrushing T-shirts at 60psi for several hours a day have had them die prematurely, sometimes in only a few weeks. Dead [xx(]
    January 2003
Posted by shermanfreak on Tuesday, August 5, 2003 2:13 PM
Thanks for the info Mike.
It's not the one that I chose for myself (I found something else along that lines though). I have heard of other modellers having decent success with this unit, but once again of course it depends upon the amount of usage.
I just supplied this picture to show a usable unit compared with the previous pic. As always it is wise to shop around and then ask lots of questions about the particular unit.
