I officially hate acrylics!
Posted by MikeV on Wednesday, March 22, 2006 1:20 PM
I have touched up spots on this F-16 Tiger Meet over and over and masked it earlier with 3M blue tape to paint the cockpit area with black and look what happened when I removed the tape. Censored [censored]
It had Future over it also but that doesn't matter when the adhesion is not sufficient underneath. Angry [:(!]
I am going to try the Tamiya acrylics this weekend and if they don't work as well as I want then I am going back to enamels exclusively.
    January 2003
Posted by Triarius on Wednesday, March 22, 2006 1:31 PM
Mike,
ModelMaster?
The greatest failing of acrylics is their sensitivity to surface contamination. I wipe down the surface with a cloth or sponge dampened with detergent and water, followed by a wipe rinse, then drying in a lint free cloth. On bare, unpainted plastic I just wipe with ethyl alcohol (Everclear), let dry, and paint.
Never had your problems—except with ModelMaster.
Posted by MikeV on Wednesday, March 22, 2006 1:47 PM
Yes Ross it is Model Master Acryl.
I may not have prepared the surface as well as I could but I did wipe it down with Polly S Plastic Prep before painting which should have cleaned it well enough for good adhesion.
Posted by Lufbery on Wednesday, March 22, 2006 2:42 PM
Mike,
I don't know if it will help you, but I prime everything with a spray enamel, and apply my MM Acryl paints to that coat (after it has cured). I don't have the problem with paint lifting off like I did before I started priming.
I use the MM Acryl paints in my airbrush because they don't smell so bad, they dry quickly, and they're easy to clean. All things that let me model inside rather than outside in the cold and wet. Smile [:)]
Oh, I spray the enamel primer in the basement, or outside in the cold and wet.
Regards,
-Drew
Build what you like; like what you build.
Posted by jhande on Wednesday, March 22, 2006 3:31 PM
Mike, not sure if what I have read is true or not. But in all the airbrushing books that I've read, they mention acrylics being a bit more stubborn adhering to plastics than enamels and recommend light sanding and a primer coat of sorts.
My 2 cents [2c]
-- Jim --
"Put the pedal down & shake the ground!"
Posted by MikeV on Wednesday, March 22, 2006 4:01 PM
Yes Jim that is true.
Not sure how I prepared this model as it has been months since I started it and then put it away.
Oh well, live and learn I say. Wink [;)]
    November 2003
Posted by ghettochild on Wednesday, March 22, 2006 4:33 PM
Model Master Acryl sucks, I could never get it to stay on. I had better luck with Polly Scale, but I would still get peeling from masking. And that was after a wash, Mr. Surfacer primer, and wearing gloves while handling the thing.
Needless to say I only use enamels, and no more problems.
-Josh
Posted by MikeV on Wednesday, March 22, 2006 4:58 PM
Well, I tried to apply the Hasegawa Tiger Meet decal on the tail and it would not cooperate at all and ended up tearing. I am real close to putting this kit under the tire of my truck and crushing it! Angry [:(!]
I guess it will have to be a normal F-16 now. Banged Head [banghead]
This has been the biggest PITA kit I have built to date.
Posted by jhande on Wednesday, March 22, 2006 5:27 PM
AHHHH  hang-on Mike!
How about rolling it back into the shop and blasting the acrylic off and going with your trusty enamels?
I know it would mean a lot of work, but you'll be salvaging it. Wink [;)]
-- Jim --
Posted by MikeV on Wednesday, March 22, 2006 5:29 PM
I don't know what to do with it now Jim.
Maybe I will strip it and paint it as an Israeli F-16A as that is a more interesting paint job then the boring "normal" F-16 colors.
Posted by jhande on Wednesday, March 22, 2006 5:35 PM
Glad to hear it's at least going to survive a thrashing under the tire of your truck LOL.
Big Smile [:D]
-- Jim --
Posted by MikeV on Wednesday, March 22, 2006 5:42 PM
Big Smile [:D]
I could still do that, make a diorama and say a SAM got it. Evil [}:)]
Posted by jhande on Wednesday, March 22, 2006 5:45 PM
LOL
I hear ya... Wink [;)]
-- Jim --
Posted by Anonymous on Wednesday, March 22, 2006 6:35 PM
Mike,
I have had this happen before and have found a simple solution.  I use 3M blue tape and I found that using the type made for delicate surfaces works best.  I have also found that using a little forehead oil to take off some of the tackiness.
After cutting the tape, I just put it on my forehead for a few seconds then put it on the model.  After coming up from the basement one evening with some tape still on my head, my wife thinks I am crazy!
Also, I usually let the first color cure at least for one day before masking.  I have used this method with good results and only use acrylics.
    December 2003
Posted by hkshooter on Wednesday, March 22, 2006 8:00 PM
I have a two word cure to what ailes you.
Enamels.
Lacquers.
    January 2004
Posted by MusicCity on Wednesday, March 22, 2006 8:59 PM
Nah.  A little bit of alcohol on a Q-Tip and a couple of minutes rubbing will blend the edges of those spots right in.  Spray over it and you'll never see it.  Rub the bad spot out, and as you widen the area slightly the edges will feather right in.  I've been having a terrible time with some Model Master Medium Green.  It keeps cracking very badly, and I've had a lot of practice using that technique the past couple of weeks.
On a related note, sort of, I sprayed some PollyScale Dark Green a little while ago.  About 15 minutes later I realized I had part of the pattern wrong, taped over it ("It" being part of the paint I had just sprayed 15 minutes previously), sprayed some PollyScale Tactical Tan over the area I messed up, pulled up the tape, and started over.  No problems at all with just a few minutes of drying time.  Note that I don't reccommend this as common practice, but I was in a position that if it pulled up the paint I was really no worse off.
Posted by MikeV on Wednesday, March 22, 2006 9:29 PM
I tried removing the tail to put on a different one in the kit to make it an F-16A like the Israeli ones and it broke leaving a huge gap so I shoved it in the box and threw it back into the closet where it is going to stay. I wanted to start on my Academy SU-27 but it won't fit in my case my models are in so once again I am screwed. Think I will go back to just airbrushing T-shirts or something. Angry [:(!]
    January 2003
Posted by Triarius on Wednesday, March 22, 2006 11:37 PM
Mike,
Some days, the dragon wins…or maybe it's the windmill. Whatever.
Illegitimati non carborundum!
Hog Latin for "don't let it get you down." For example:
I have been an archer since I was six years old. This year, with a new bow, I was determined to practice regularly enough to really hone my already very good marksmanship, and blow them away in the winter league. (Took first last year.) Then I got "retired," tore out the old kitchen, put in a new one, and had arthritis flare up in my elbow. Needless to say, I didn't shoot very well this year.
These things happen. They are transitory, no matter how frustrating they may be at the time. Failure is merely an opportunity to learn better.
So take a break. Use this opportunity to look carefully at all your successes of the past, and really appreciate them. You should find that rewarding and encouraging.
Posted by MikeV on Thursday, March 23, 2006 12:50 AM
Thanks Ross, I appreciate the pep talk. Thumbs Up [tup]
I was just blowing off steam.
I have the kit out again and am doing some heavy Tenax and CA glue work on the original tail section and then I am going to cut it off flush with the fuselage and glue the other tail on.
Posted by Anonymous on Thursday, March 23, 2006 3:34 PM
Mike, don't forget to try that Tamiya this weekend. Are you going to use it with laquer thinner as some have suggested?
E
Posted by MikeV on Thursday, March 23, 2006 4:33 PM
E
No way! Why would you use lacquer thinner for an acrylic paint?
I will try my 91% isopropyl alcohol/filtered water 50/50 mixture to thin it and see how it does.
If I don't like the results then it's back to enamels. Wink [;)]
Posted by Kolja94 on Thursday, March 23, 2006 5:23 PM
I've had similar problems with Model master acryl, but have had really good luck with Polly Scale acrylics.
Karl
Posted by Anonymous on Thursday, March 23, 2006 8:45 PM
 MikeV wrote:
E
Mike, I was referring to a post by Greg back on 12-27-2004 about thinning Tamiya acrylics with lacquer thinner. I believe your original reply was that it would defeat the purpose of geting away from the fumes and such. But Greg swore by it and said the paint flowed and leveled nicely. I may try it when the weather gets better for outside airbrushing.
E
Posted by MikeV on Thursday, March 23, 2006 9:23 PM
That is interesting.
Greg posted the other day that he uses denatured alcohol for Tamiya paints and is very happy with the results.
    January 2003
Posted by plasticmod992 on Friday, March 24, 2006 2:34 AM
True guys, I did post the use of laquer thinner with the Tamiya.  It was just a test run inspired by another modelers results.  I currently use the Denatured Alcohol exclusively.  It has proven to be a very excellent plastic prep, thinner and airbrush cleaner for Tamiya acrylics in my experience.  ARC will be publishing my article on my lasted effort, an F-14B (AA-102) from VF-103, "Jolly Rogers", painted again, entirely with Tamiya acrylics! (Photo below)  I no longer use any enamels or laquers, for all the reasons I mentioned in a prior posting, in response to MikeV's "Acrylic -VS- Enamel" thread.
MikeV, don't give up!  Ditch the MM Acryl and go Tamiya.  I would follow MusicCity's advice for correcting the area, save for the other damage in pulling off the tail (snicker) and finish the model.  After sanding the area smooth, and if you want to finish things up this weekend armed with Tamiya acrylics, here are the paint mixing formulas for the base colors you'll need for your F-16 color scheme.  I presume it wears the "Hill scheme" base colors.  Good luck my friend! Here are the equivelicies:  Oh... FYI, the photo of my model below is meant to be a source of inspiration, not to toot my own horn.  More to demonstrate what Tamiya acrylics can do for your models, I know I'm sold!
F-16 base color(s)  "Hill scheme"
Tamiya Acrylic equivelencies:
FS36270- XF-20 (* Add a few drops of X-2 if it is too dark to your eye)
FS36118- XF-24
FS36375- (15 drops/ parts) XF-2, (3 parts) XF-24 and (2 parts) XF-66
Sneak preview:  My lastest build, AA-102, VF-103, Operation Enduring Freedom, 2002 "low-vis" scheme. Painting and finishing using Tamiya acrylics.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by MikeV on Friday, March 24, 2006 3:39 AM
Thanks for that info Greg, you are always a big help my friend. Thumbs Up [tup]
I have decided to paint the F-16A in Israeli 3-color camo as I have always loved the looks of them.
    January 2003
Posted by plasticmod992 on Friday, March 24, 2006 7:27 PM
And you're always welcome Mike.  That will surely be a striking model when complete..can't wait to see it finished.  Ok...well, don't leave us all in limbo here, what did you decide?  Enamels or acrylics??? LOL!  It was a hard decision for me, like yourself and others I'm sure.  I had enamels in my blood, so to speak, ya know?  It was hard during the transition not to grab that dependable bottle of FS "whatever" from the rack.  Well, at any rate,  good luck with whatever you decide and lets see some in-progress pics when you get an opportunity.  Later.
    July 2004
Posted by tho9900 on Friday, March 24, 2006 7:34 PM
Greg - it was the same for me... especially early on when I was learning how to spray acrylics right and had theusual pull up and such... once I figured out a system and found the paint I like, I will never go back.  (ok I still do use the occasional enamel for brush painting.  Basically when that enamel stash gets used up it will be pure acrylic though)
Posted by MikeV on Friday, March 24, 2006 9:32 PM
Greg,
I want to try the Tamiya acrylics on this kit.
Does iso alcohol or ethyl alcohol seem to work as well as denatured that you use?
Just curious if you have tried other types and settled on the denatured because it was better?
I have some work to do on it before I can repaint it as I am still trying to strip the old paint off which is a slow process as I can't submerge it in Super Clean as the cockpit is finished.
Then I have to put on the standard tail and then she will be ready to paint.
I have to figure out the colors I need also for that paint job.
    January 2003
Posted by plasticmod992 on Friday, March 24, 2006 10:47 PM
I settled on Denatured Alcohol due to a difference I noticed in the atomization, spraying characteristics, and the final appearance of the paint once dried on the model.  The difference was, when thinned with 91% Isopropyl alcohol, the paint film was extremely dry, almost chalk dry, if you will.  And when I went over a previously sprayed area to fill in, say a camo outline, I experienced blushing, as if the spray from the airbrush was rewetting the dry surface film.  It looked very odd, and again very, very, dead flat.  The result early on with this, was frequent poor adhesion..even Tamiya masking tape seemed to pull the fully cured paint film right off, dispite a very clean bare plastic surface.   This prompted me to try 70% Isopropyl, with more water content.  While it thinned the paint fine, atomization suffered, due to, I suspect to the surface tention of the water in the alcohol, and in some cases, even with retarders added to compensate.  My demands were high, as the mix had to spray finelines for my 1/72nd scale jets.  I then pulled out FSM's old book, "Painting And Finishing Scale Models" authored by Paul Boyer, 1992.  I went to the chapter: "Using acrylic modeling paints", where he experimented with popular acrylics and their thinners.  Wooh, to my surprise, Paul tried *Denatured Alcohol, (pictured on page #59 of the article)  Paul mentioned he tried denatured alcohol as well as Isopropyl  for some of the acrylics he sprayed, namely Tamiya.  So I paid a meger $2.99 for a Quart at the home store, gave it a shot, and alas...... it worked very well!
This time, the paint seemed to mix more thouroughly  and atomize finer than other alcohols.  Fine line spray was emmediate, easy to achieve, control, and maintain.  And lastly, the paint film had the same characteristics like that of enamels when the spray contacted the models' surface.  The freshly sprayed paint stayed shinny or "wet" for a few moments on the models surface and slowly dried to an  even, smooth sheen with no blushing or "dead flat" appearance.  Glosses stayed glossy and flats were slightly satin, to my surprise.  I didn't have to use retarders either. The denatured alcohol seemed to re-wet any dried paint on the tip, if any, from the airbrush's needle- just like enamels and mineral spirits.  The kicker was that, adhesion was excellent, far superior- after letting the paint cure for as little as an hour, even faster cure in my home-made drying oven.  Masking tapes didn't budge it.  So this was the experiences that lead me to settle with Denatured Alcohol.  If you can get your hands on these older FSM books, do so...they retrained me in scale modeling.  Hope this inspires!
