New Testors/Aztec airbrush-need help!
    April 2006
Posted by Irish3335 on Wednesday, April 19, 2006 10:51 PM
Hi all,
first of all, just wanted to thank everyone who takes the time to respond to all my posts and questions.  Ok, to the bulk of my question: I just purchased an Aztec/Testors air compressor, with the shut off switch, compression adjustment, etc...really nice small compact compressor that is awesome.  Question is, how do I work at doing the tight, controlled lines such as small lines, detail lines, feather spraying for camo, (such as on an F-4) or lines on a tank (such as a German Panther or Tiger).  Any help is greatly appreciated!
Thanks again
    December 2004
Posted by Hippy-Ed on Thursday, April 20, 2006 12:55 AM
Well, if you are new to airbrushing (like meBlush [:I]) it takes practice. practice. practiceSmile [:)] I am unfamiliar with your A/B but, you'll need to find some scrap plastic & and go to town on it adjusting your air pressure, paint/thinner ratio & such. others will know more & will be able to answer more thoroughly.
 hth,
 Eddie
If you lose your sense of humor, you've lost everything
    October 2005
Posted by usmc1371 on Thursday, April 20, 2006 8:15 AM
When dealing with Aztek airbrushes, it kind of depends on which airbrush you have.  So, which Aztek airbrush do you have?  Here are some genearlly guidelines when airbrushing fine lines:
Method 1:
Thick paint (viscosity - high)
High pressure (30 psi and up)
This allows you to paint fine lines when the needle is partially retracted into the airbrush.
Method 2:
Thin paint (viscosity - low)
Low pressure (10 - 15 psi)
This combination produces fine lines with the needle fully retracted into the airbrush.
This information comes from Testors website : http://www.testors.com/hobbyist_guides.asp  Click on Chapter 6 and scroll down to the heading Perfecting the Balance of Fine Lines.
I  use two Aztek airbrushes, the A470 and the A320.  Let me know if you have any other problems.
Jesse
