SNJ Advice
    January 2006
SNJ Advice
Posted by DiscoStu on Monday, May 8, 2006 2:33 PM
Hey all.  I'm about to try using SNJ's metal finish and rubbing compound on A.M.'s Vindicator.  I've never used this stuff before.  Any advice or tips before I spray away?
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    May 2003
Posted by DrewH on Monday, May 8, 2006 8:53 PM
Yea, I have a couple. First read their directions. you can't go wrong there. I use a siphon jar with the siphon tube cut up about 3/16" from th bottom of the jar. This is to keep the metal particles from settling and then not enough carrier (clear stuff ) mixed in causing a grainy finish. As the time passes keep giving it a swirl every so often to keep everything mixed thourghly. The directions say to "mist" in 3-4 light coats. This is crutial. If you flood the model with it, you will end up with a finish that resembles orange peeling. SNJ is a "hot" paint. It will eat into the plastic if too much is applied at one time. I set my airbrush to the finest setting to spray. This stuff is so thin it floods easily. I often wind up applying 5-6 coats for coverage to avoid flooding and eating of the plastic.
Good luck
Drew
Take this plastic and model it!
    January 2006
Posted by DiscoStu on Monday, May 8, 2006 9:56 PM
Don't have a siphon feed airbrush.  Both my airbrushes are gravity feeds.  Any additional advice there?
Posted by tyamada on Tuesday, May 9, 2006 9:31 AM
Make sure you have enough SNJ to do the job, because I believe that the company has gone out of business.  The only SNJ available is whats out there right now.
    January 2006
Posted by DiscoStu on Wednesday, May 10, 2006 2:10 AM
No pressure.  Right.
