Dull vs bright
Dull vs bright
Posted by urich on Thursday, May 11, 2006 10:29 PM
I have a couple of modles that call for places to be bright aluminum and other places to be dull aluminin how do you do this? thanks J Urich
Posted by MikeV on Friday, May 12, 2006 7:59 AM
You could spray clear flat on the "dull aluminum" parts and leave the "bright aluminum" glossy.
Posted by Anonymous on Friday, May 12, 2006 8:44 AM
That would be my suggestion too as I've never seen a "flat-aluminum" at least not readily available in a bottle.
Of course with as long as I've been away from the bench they probably have one out now.
    August 2005
Posted by Phil_H on Friday, May 12, 2006 8:52 AM
Actually, Tamiya make a Flat Aluminum - XF-16.  However, if the difference between "bright" and "flat" is quite subtle, I'd go with the "clear flat" over the "dull" areas too.
Posted by urich on Friday, May 12, 2006 9:19 AM
Mike how do you go about masking the color to spray the say the silver color.  In other works when I paint silver then mask even with a low tac tape I end up pelling off some of the paint? When I'm home I have to work fast to complete just a few of the kits before I leave again. so time is not on my side. J
    February 2006
Posted by Neptune48 on Friday, May 12, 2006 10:53 AM
I'd recommend switching to Alclad 2.  They have seven variants on aluminum* and the paint does not lift when masked.  A single bottle looks pricey, but it goes a long way and yields superior results.  BYW, I'm not affiliated in any way with the company, just a fan who has done a little research.
http://www.alclad2.com/alclad-home.html
*Alclad 2 Aluminum paints:
Polished Aluminum      Dark Aluminum      Duraluminum      Aluminum
White Aluminum          Dull Aluminum        Airframe Aluminum
"You can't have everything--where would you put it?"
Posted by MikeV on Friday, May 12, 2006 8:33 PM
What paint are you using and how are you preparing the surface?
Posted by urich on Tuesday, May 16, 2006 10:40 AM
I do the standard soap and water wash and let dry the paint i use in Model Master And I use the Blue masking tape or low tact scotch tape But I think I will try some of the Alcad paint when I get back to the states
