Compressers
Compressers
Posted by Anonymous on Saturday, May 20, 2006 4:29 AM
Hey everyone
I've recently got an airbrush and am currently using propel cans. They are expensive in Australia Disapprove [V] ( i don't know about the states). So I have a compresser allreday, although it is just a regular household one, simply getting a regulater will make it suitable for airbrush use by making it a regular flow, wont it?. I know about moisture traps, so you don't have to tell me that.
Will
    January 2004
Posted by MusicCity on Saturday, May 20, 2006 5:28 AM
Yes, a general purpose compressor will work just fine as long as you can regulate the pressure down to something usable for an airbrush.  I use a 15-gallon, 150 psi general purpose compressor and regulate it down to about 15 psi for airbrushing.
Posted by Anonymous on Saturday, May 20, 2006 5:53 AM
so thats it, just a regulater you attach straight onto the compresser? Approve [^]
    August 2005
Posted by Phil_H on Saturday, May 20, 2006 7:02 AM
Yep - all you need is a suitable regulator and the correct adaptor for your airbrush hose.
    January 2003
Posted by Triarius on Saturday, May 20, 2006 10:37 AM
Something that will help, especially if you want to do fine detail work, is a stilling tank. This can be anything from a true storage tank to a small tank in the line. This removes the pulsations from the compressor. The tank goes before the regulator.
If the compressor does not have a tank, one can be fitted from an old scuba tank or other gas cylinder and fittings available in most hardware stores.
    May 2005
Posted by Bgrigg on Saturday, May 20, 2006 10:49 AM
Run a line to your work area and put the regulator at the "business" end. That way you can control the pressure without interrupting the work flow. I have a moisture trap attached to the regulator, then the line to the AB. Works great.
And yes, propel cans are stupidly expensive!
So long folks!
Posted by Anonymous on Saturday, May 20, 2006 5:36 PM
Thanks Everyone
I just wanted to make sure before I went out and bought one, and i'll look in to the tank thing Ross.
Will
