Hi all. I would like to thank all of you for the help with what I am doing now. But I have 1 last thing to ask " I don't want to mess up with this " .
OK I got my Omni 4000 and I am getting ready to use it for the 1st time.
1. I was told that I can use Distilled Water or Tamiya Acrylec Thinner to thin the paint out. How much should I add to the paint to thin it out ?
2. I am going to be using Windex to clean out the A/B. So I just pour out the paint that was left over and add Windex and turn the PSI up and spray, right ? Do I just spray into the spray booth or get that spray thing you just spray into " Like a little contaner " ?
3. I heard something, someone said about using some kind of oil or gress or something you dap on the tip of the A/B to keep it clean when you are using it. What was that ?
4. How much PSIs should I be using on the Compressor to paint ? And I know to turn it up when uing Windex to clean it. I have a Scorpion II Compressor.
Thanks again all
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
