Tamiya fine surface primer..
Posted by ipms40049 on Tuesday, July 4, 2006 9:31 AM
.. is this stuff enamel based? Its the one in the rattle can.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    May 2005
Posted by Bgrigg on Tuesday, July 4, 2006 11:38 AM
Huh, their website has zero information on it. The other Tamiya rattle cans are synthetic lacquer, so I suppose one could extrapolate that it's lacquer based. I'll try to get to my LHS  today and see if they have a can in stock.
edit LHS is out of stock, expecting shipment Wednesday. Will confirm ASAP /edit
So long folks!
    August 2005
Posted by Phil_H on Wednesday, July 5, 2006 4:44 AM
I haven't used the rattle-can version, but I can tell you that Tamiya's "Liquid Surface Primer" in the jar is lacquer based. It's actually very similar to the finer grades of Mr Surfacer. I would assume that the canned version is also lacquer based.
Posted by jhande on Wednesday, July 5, 2006 9:17 AM
What is the product # ?
It seems that Tamiya's spray cans are a "synthetic lacquer" and most likely so would be the primer.
-- Jim --
"Put the pedal down & shake the ground!"
    January 2006
Posted by PatlaborUnit1 on Tuesday, June 26, 2007 8:57 PM
Just to continue an older thread I came in just to look this up. I just shot some "Tamiya  Fine Surface Primer White (L)" [what's the L for ?] and it seems to be a synthetic lacquer not much different than the Duplicolor that I use all the time on my figures. It went on very smoothly and dried quickly. First coat was a bit dusty, second coat smoothed that right out.
I will try to polish it out with 000 steel wool on the areas that will be armor and flesh. BTW this is going over my Rathalos Armor Hunter figure, previously primed in Duplicolor light grey sandable primer already rubbed down with 000 steel wool.
I plan to finish with Alclad and acrylics.
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
