Clearcoats
    April 2005
Clearcoats
Posted by Thunderbolt379 on Monday, September 18, 2006 8:32 AM
Hi all,
I have the Microscale acrylic topcoat range but I've not used them before, and I was hoping for some advice.
First, they're "milky" in the bottle, not clear -- are they supposed to be?!
No thinning ratio is mentioned, just that water is recommended. What ratio do folks find works? Should I use distilled water?
When clear-coating to provide a foundation for decals, is it wise to overcoat the whole model in a continuous coat of gloss, or just the areas where the decals will go? The satin or flat final coat to seal the decals will pull the gloss back, of course, but if you've used only "patches" of gloss, do you get a "tide-mark" effect around them, visible through the final coat?
And finally, how tough are these coats? Will they stand up to handling, polishing and the like?
Cheers,
TB379
http://worldinminiature.blogspot.com/
    February 2006
Posted by Wilbur Wright on Monday, September 18, 2006 12:13 PM
Personally I would do the whole model and not spot it. I use Model Master flat to seal all my models (planes ships armour)........I find it to be pretty tough.............gloss would probably be more suseptable to marks etc.  As a rule the acrylic will be milky before its dry. I would try to find others on here with experience in that very topcoat. Do not apply too thick. Use several light coats.
    March 2004
Posted by Mark Joyce on Saturday, September 23, 2006 9:32 AM
I'll try to answer these questions in order based on my limited experience with Microscale:
Yes, they are milky in the bottle but dry clear;
I would recommend distilled water, but as to thinning it might be a trial and error experiment;
Many people glosscoat the entire model, but others only where the decals go.  I glosscoat the entire model since I usually use a wash in the panel lines, and the gloss helps the wash flow.  I've also tried using Future floor polish as a setting solution for decals, with good results.  When I do this, I only use the Future where the decals will go.  However, I'll still apply a glosscoat over the entire model (including said decals) for the wash.  One reason I do it this way is to cut down on the number of glosscoats on the model so not to fill in those panel lines I will apply the wash to.  When I've done it this way, I've not a problem with any noticeable ring.  But as I said, I follow up with another glosscoat;
The coats are fairly durable and should hold up to some routine handling, but I'm not sure about polishing.
Now that I've said all this, I don't use Microscale gloss or flat anymore.  Personally, I use Future floor polish for my glosscoat and Pollyscale Clear Flat for my matte coat, which is an acrylic.
Hope this helps!
Mark
Ignorance is bliss
