Future issues...grrrrr
    May 2003
Posted by klem on Friday, October 6, 2006 1:45 PM
What am I doin wrong...I just sprayed my Viking with Future, put it on in a couple light coats first then let it dry. It pooled up due to gravity in certain locations. I went light with it but it pooled anyway. Just put the second coat on today in lighter coats and its still pooling though not as bad. I'm spraying it right out of the jar without thinner at the right distance but its still not cooperating. I was able to get rid of the pooling from the first layers with a bit of windex, swabs and cotton cloth. Help?!?!Confused [%-)]
"We the unwilling, led by the unknowing, are doing the impossible, for the ungrateful. We've been doing so much for so long with so little we are now capable of doing anything with nothing." Unknown
Posted by Anonymous on Friday, October 6, 2006 4:37 PM
i often had the same problem when spraying Future.i started now to brush mine on and low and behold,i never had the problem again
    January 2003
Posted by Triarius on Friday, October 6, 2006 8:28 PM
A "light" coat of Future is a mist coat of anything else. It's actually okay to start with coats so light that they look pebbly, and build them up. The first coat should be very light, the second can be heavier, but you want just enough to make the surface look slightly wet. I haven't looked at it microscopically, but Future seems to fuse with previously dried coats seamlessly.
    May 2006
Posted by Storch on Friday, October 6, 2006 8:47 PM
I think it's that Future dries much more slowly than normal acrylics do, so you can lay it doen thin and it will level afterwards as opposed to trying to make the coat as smooth as possible as you lay it, if that makes any sense.
    September 2006
Posted by ZzZGuy on Friday, October 6, 2006 10:25 PM
Perhaps trial and error on a scrafical model?
Mongol General: Conan, What is best in life?
Conan: To crush your enemies, see them driven befor you, and hear the lamentations of the woman!
