Iwata Revolution CR
Tamiya or MM Acrylics
I'm having a really hard time getting the hang of airbrushing - most due to the sticking of the needle within the tip. I can't get through half a cup before having to unscrew the back half and gently pull the needle free then reseat - continue painting. But, apparently, there is build up or something as the spray can be very "pulse - ish".
I do use a bit of Tamiya thinner per cup - and water for MM - but it still sticks. :\
I read on here about using a retarder to help with this? But I wasn't sure if this was for the problem I having or not.
Would such a retarder be like this one:
http://www.dickblick.com/zz006/28h/
Will this help?
Thanks
Dodge
