Count your blessings and start painting…
The only reason to prime with a different color in your case is to find defects in the plastic finish—amazing what shows up with a coat of flat primer. In your case, I'd use a very light gray. Because gray is a neutral color, it makes it easier to spot defects in the model's surface.
You could prime with a flat white, too.
