Using Future as mask on clear plastic?
DCV
    July 2006
Posted by DCV on Tuesday, December 5, 2006 4:51 AM
Has anyone used Future as a mask on clear plastic parts? I have a project with very poor fit on some clear parts and can`t get a very good mask out of masking tape. Seems I recall hearing Future used for this but I`m not positive.
    November 2003
Posted by bobbaily on Tuesday, December 5, 2006 5:55 PM
DCV-I could be wrong, but I can't see Future being used as a masking agent.  As far as the fit on the clear parts, you might try some white glue (Elmer's) or check with a hobby & craft shop for a thicker version of Elmer's.  As far as masking issues, check out Swanny's website under Tools & Tips.  Also there is some good info regarding & using Future.
  http://swannysmodels.com/
Bob
    January 2005
Posted by jinithith2 on Tuesday, December 5, 2006 6:28 PM
I don't think you can. dried Future comes off only when it is soaked in wet Future, and it MIGHT work, but I wouldn't rely on it.
    January 2006
Posted by PatlaborUnit1 on Tuesday, December 5, 2006 9:09 PM
DVC
definitely not. I use Future to clear coat my canopies and its an absolute bear (soak in ammonia) to get off when dry.
I also use it as a PE adhesive and decal adhesive.  Better sticking than un-sticking properties.
 Try Masking Sol NEO or Winsor and newton art mask.....
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
Posted by ABARNE on Wednesday, December 6, 2006 1:43 PM
DCV, what kind of masking tape are you using?  Tamiya's Yellow tape, athough a bit pricey, is extremely thin, can conform to compound curved surfaces,  and cuts extremely well.
jwb
    February 2006
Posted by jwb on Wednesday, December 6, 2006 2:12 PM
I've used Bare Metal foil and it works great, but every now and then I run into a small or odd shaped spot that won't wask easily. I use a toothpick and apply several coats of white glue. Once the paint is on and dry, I just use the end of a toothpick to pry it off. Works great!
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
DCV
    July 2006
Posted by DCV on Wednesday, December 6, 2006 3:34 PM
I`m having problems with the front and rear windshield on a 1/35 scale Russian URAL heavy truck made my ICM- problem is that when trimming the masking tape after putting it on the clear part, the plastic is so soft, and the parts fit so poor, that the knife blade won`t follow the window outline, it makes its on path where ever it wants to go. I had to cement the windshields in place due to the design of the kit and then mask the clear sections so I could fill in the huge gaps and have my filler covered by my airbrushed finish coat, just the problem with the masking is holding me up. The tip on using white glue sounds interesting, I think that`s what I`m going to try. I had thought that in `The Complete Future` it mentioned using Future as a masking material, I reread that several times and it in fact doesn`t mention that, I can`t think where I heard or read of that tip- either my source was mistaken or I`m not remembering correctly ( the memory thing is entirely possible- middle age and everything you know :) )
    December 2006
Posted by gemini on Thursday, December 14, 2006 9:02 AM
use the white glue i have been using it for a long time and works well for me just put a few coats before spraying
1/48 scale Academey Mig-21MF- 100% Complete 1/48 scale Academey Republic P-47N - 100% Complete 1/48 scale Academey Locheed F-16c- 60% Complete 1/48 scale Tamiya Gloster Meteor f.1 -90% Complete 1/48 scale Academey Messerschmitt Bf109G-14 - 100% Complete 1/48 scale Tamiya Messerschmitt me262 A1a -60% Complete 1/48 scale Dragon FW190a-7 sliper tank 0%Complete 1/48 scale Tamiya mosquito PR MK.IV 100%
Posted by waikong on Thursday, December 14, 2006 10:06 AM
They also make liquid mask for specifically this purpose, just make sure you use several coats.
