Spraybooth...Too much airflow?
    November 2006
Posted by buildit on Wednesday, February 7, 2007 7:56 PM
I've searched and found quite a number of threads about building a spraybooth but one thing I don't recall seeing (or may have missed...) is much discussion about the possibility of having too much airflow through the booth.  Is it realistically possible to have too big of a fan?
I'm considering building myself a booth and I have some complete squirrel-cage fan set-ups that came off of the solar heat system that used to be on my house.  The fan is 6" diameter and 3" wide, and in the solar system was moving air through 6" ID insulated ducting hose.  I have no idea what cfm they would be, but I'm sure one of them would be plenty for a 24x18x18 spray booth, but should I be concerned at all about it being too much?  Or is this just a non-issue?
    May 2005
Posted by Bgrigg on Wednesday, February 7, 2007 8:35 PM
Yes, in fact it might be worse to have too much airflow as opposed to not enough. Too much and the paint might not even get to the surface before being whisked away by the air current. Or it might cause the paint to dry too quickly resulting in orange peel or rough surfaces.
Check out this LINK for an article on fan selection.
So long folks!
    May 2003
Posted by styrene on Thursday, February 8, 2007 5:57 AM
Sign - Ditto [#ditto]   What he said....
Gip
    January 2007
Posted by Gigatron on Thursday, February 8, 2007 9:18 AM
I'm building a booth with the same exact dimensions as you are (24x18x18), but I'm using 2 240 CFM bilge blowers invidually powered.  It'll give me the ability to turn off one blower if two are too much for what I'm doing.
I was originally planning on a 1" deep plenum between the diffusion plate and the back of the booth, but I like the idea of a 2" with an opening escape hatch to cut down on pull-through.
I hope I figure out all the design issues before I sit down to build the thing Cool [8D]
-Fred
    November 2006
Posted by buildit on Thursday, February 8, 2007 7:02 PM
Thanks for the input!  Looks like I've definitely got some figuring to do.  I'm thinking about trying to go with a downdraft design, but that's still under consideration.  I have a feeling that the fan I have may be a bit much, but I'll do some more studying then make the call.
Thanks again!
    May 2003
Posted by styrene on Thursday, February 8, 2007 8:01 PM
buildit wrote:
"I'm thinking about trying to go with a downdraft design, but that's still under consideration.  I have a feeling that the fan I have may be a bit much..."
Keep in mind that downdraft booths don't need the same amount of airflow as a laminar flow booth does, because the downdraft relies on gravity and heavier-than-air solvent vapors to assist in the work effort (Interestingly, every solvent vapor we use in this hobby is heavier than air, with the exception of water vapor).  Downdrafts usually only need something on the order of about 50fpm face velocity for vapor capture as compared to 100fpm for a laminar flow booth.
There are, however, some additional design considerations.  In order to even out the airflow, you should consider using some sort of evenly perforated surface covered with a filter to place your model on for spraying. Holes should be large enough to allow adequate airflow.  Holes too small plus a filter will provide quite a bit of resistance to your fan, and impede exhaust efforts.  In addition, adding a small plenum below your surface will provide more even distribution of the airflow within your booth, as it equalizes airflow pressures, and provides for adequate vapor capture equally across the perforated surface.
Hope this helps some.
Gip Winecoff
