Primer for Metalizer?
    February 2007
Posted by Shogun on Friday, March 2, 2007 6:12 PM
I have learned through this forum that the Model Master Metalizer paint is a bit fragile in terms of it adhering to the model surface, especially when you mask over it.  I was wondering if using primer as a base coat would help at all?  If so I imagine an enamel would be best.  Any thoughts?
Travis
Travis Parker On the Bench: - F4G/F Phantom II "Wild Weasel" (Testors) - Ducati Monster S4 motorcycle (Italeri)
Posted by Anonymous on Friday, March 2, 2007 10:18 PM
I'm going to reply with a disclaimer. My use of metalizers has thus far been limited to small things and I haven't had any issues. That said, in theory . . .
Yes, a primer should help. Metalizer I noticed doesnt cut good with mineral spirits but does with lacquer thinner. I assume from that + odor that it's a lacquer base, which makes the most sense to me. Lacquers dont tend to like plastic much. While I'm sure that they've done what they can formula wise to overcome this, anything you can do to give it something better to bite on, like an enamel, should go far.
Now that you've posed this question I have an experiment I think I'll try tomorrow with some spare plastic. I use a vinyl based lacquer sealer in furniture when I'm dealing with woods that have natural oils (very few - rosewood, cocobolo) that will bond to almost anything. I ought to try shooting that on plastic and see if it bites or if its too hot and just melts it.
Posted by Anonymous on Saturday, March 3, 2007 12:15 PM
Update: Thats how experiments go. Vinyl sealer will definately NOT stick to plastic. It didnt melt it. Looked pretty decent until I tried to do a little abrasion test on it, at which point it rolled right off with a fingernail.
Posted by tyamada on Saturday, March 3, 2007 1:30 PM
Model Master Metalizer is designed to be used on plastic without primer.  You should polish your plastic with rubbing compound or micro mesh, this will give you a smooth base.
I have use Future as a base/primer for Model Master Metalizer and have had good results, but it is still fragile.
Posted by ajlafleche on Saturday, March 3, 2007 2:13 PM
Metalizer lays down a very fine and thin coat. Primer leaves rough surface. Metalizer will show that graininess, spoiling the effect of natural metal.
Posted by Anonymous on Saturday, March 3, 2007 8:16 PM
Testors has a good tutorial on their website concerning painting with Metalizer.
E
