- Member since
May 2003
Posted by kirk4010
on Friday, March 30, 2007 4:15 PM
The only reason to seal is if you are going to do some weathering, say try to darken some panel lines. In that case you can use future, but you apply decals directly over it. I just did my first plane with it last week, I did'nt have an problems with it rubbing off. So I would got back to what primer you used.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
