I have one, and enjoyed using it. I eventually switched to an Aztek, but not because I found anything wrong with the Paasche, so much. I sort of fell into both airbrushes at the same time, and ending up preferring the Aztek.
The VL's adjustment wheel is real handy.... get familiar with that! It's great.
I found that I used the #3 tip almost exclusively. I thought the tip size determined spray pattern, but in researching it I found that they had to do with paint thickness.
I picked up a couple of additional paint cups so I could switch colors fast, and kept a siphon jar handy full of solvent to clean the brush between color changes.
Keep it clean and maintained and it should be a good airbrush.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
