Tinning Tamiya acrylics!
Posted by Anonymous on Saturday, June 16, 2007 9:52 PM
 I'm having trouble getting the right combo of thinner/paint for tamiya acrylics, I'm using thier thinner. Any help would be much appreciated
 Also, what presure should I be spraying at? (I've got a Passche VL)
    September 2003
Posted by Daywalker on Saturday, June 16, 2007 11:32 PM
When thinning Tamiya paints, I usually thin between 60/40 and 70/30 with their thinner.  I don't use a measuring cup, just keep practicing until it works out.  As for pressure, I usually spray between 15 and 25 psi.  Not sure if this helped, or made it worse!
Frank
    January 2003
Posted by Triarius on Sunday, June 17, 2007 10:57 AM
I usually use 90 percent isopropyl alcohol and a tiny amount of Golden acrylic retarder. I'm told the Tamiya brand thinner already contains retarder, so don't add any more if you use it.
I measure my reducing (thinning) solvent, now mainly so that I have a known starting point, and then add small amounts until I get the consistency I want: the consistency of 2% milk. Take your clean mixing container (a small, smooth-sided plastic or glass container that holds no more than about 2 ounces) and pour a little milk into it. Swirl it around to see how it looks in the container as a reference. Drink or discard the milk (or keep a glass of it handy as a reference until you get the knack.)
I usually spray between 10 and 15 psi, depending on what I'm painting. Fine work at low psi, coverage work closer to 15.
Clean Tamiya paints from the brush with Windex followed by a water rinse immediately after use. Once dried, they can be a puppy mother to remove.
Posted by Anonymous on Tuesday, June 19, 2007 3:19 AM
k thanks.
    July 2003
Posted by zokissima on Thursday, June 21, 2007 1:27 PM
I tend to use about a 50/50 mix of Tamiya paint and their thinner. Its what I found to work the best for me.
