Tamiya Acrylic Question about german yellow.
Posted by Anonymous on Friday, June 29, 2007 5:13 AM
What Tamiya acrylic colours should I be using if I want to represent German yellow, I know there are a few shades, i'm looking for a yellow that would of been seen on a MArder 3 H around 1944 in Italy.
 Also whats the rule thumb... yes to:
 Enamels over Acrylics or Acrylics over enambels
THanks for help.
Posted by ajlafleche on Friday, June 29, 2007 7:20 AM
As I noted inyour other thread, these colors are not matched to anything. Better to invest in Model Master which are matched to specific colors.
Posted by ABARNE on Friday, June 29, 2007 1:42 PM
I've always heard the Tamiya's XF-60 Dark Yellow is supposed to be quite close to what the Germans generally used.
As long as you allow proper curing, you can use enamels over acrylics and vice versa.  In fact, when you're applying washes or brush painting, it is often advantageous to use the opposite of what is underneath so what you are painting/washing with won't dissolve the under coat.
    April 2005
Posted by T_Terrific on Friday, June 29, 2007 4:07 PM
Sign - Ditto [#ditto]
Also this takes care of the acrylics vs. enamels question, as with Testors MM paints you can use either or both on the same subject with no discompatibility or chemical reaction concerns.
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
