Dull Coat
    March 2005
Dull Coat
Posted by gpal on Sunday, July 8, 2007 4:19 PM
Hello,
Can you spray testors dull coat out of a can over Tamiya acrylics. What I am thinking of doing is applying (brushing) future on the areas of the model that will take a decal over the Tamiya flat paint and then spray with Testors dull coat out of a can over the whole model after the decaling is complete. Does this seem like it will work or are there better ways?
Thanks, George
    May 2003
Posted by qmiester on Tuesday, July 10, 2007 6:00 AM
If the acrylic paint has cured completly you shouldn't have any problems with a reaction between the Dull Coat and the acrylics - and I've brush painted either Gloss Cote or Future on only the areas that the decals  and then spray coated the entire model w/dull clear flats of one brand or another on my armor models for years w/out any problems. (although I do use enamels)
Quincy
    August 2005
Posted by Phil_H on Tuesday, July 10, 2007 6:38 AM
As mentioned above, make sure the acrylic is fully cured first. As an added precaution, apply a layer of Future over the decals. Many many years ago, I sprayed a coat of Testors Dullcote over bare decals and was treated to the sight of the decals literally splitting and curling up before my eyes. Oops [oops]
Go light on the Dullcote - don't apply it too heavily or I can guarantee it will eat your base coat and decals. Mist it on, one thin layer at a time and allow it to dry before applying the next. If in any doubt, test on scrap first.
DISCLAIMER: I don't use Dullcote (Testors) - I use Gunze Acrylic clear flat as a "flat" coat.
    June 2007
Posted by JoeU on Tuesday, July 10, 2007 5:06 PM
I've been wondering the same thing for a few days now. I'm brand new to acrylic paints, only having used enamels before. So how long should you wait to make sure the acrylics are completely cured before applying Dullcote?
    May 2003
Posted by qmiester on Tuesday, July 10, 2007 5:36 PM
When I was into figures, I used acrylics as a base under my oils and I usually let the acrylics dry 48 hrs before I overcoated them.
And I only apply Future over the decals if I am building a gloss finished model.  When the overcoating of decals first came into modeling, it didn't take too long to learn that if the decals weren't completly dry (or very old), the clear overcoating  (Dull Coat or Walthers DDV)would lift and wrinkle and literaly destroy them.  The secret is to treat them like a coat of paint and be sure they are completly dry before applying the over coat (again, a minimum of 24 hrs between application and overcoating) - at least that's what works for me.
Quincy
