Badger 100g fine needle
    March 2005
Posted by gpal on Sunday, July 22, 2007 2:19 PM
Hello,
I am in the market for a gravity feed airbrush and I am looking at the Badger 100g but I am not sure to get the fine needle or the medium needle for the small jobs and detailing. I use Tamiya acrylics and have a Badger 200nh for the large jobs.
Thanks, George
    May 2005
Posted by Bgrigg on Sunday, July 22, 2007 2:57 PM
IMHO the medium needle will handle 95% of what you wish from it. I have both fine and medium, and I have yet to require switching them over. In fact, the fine needle is designed more with inks in mind, than the relatively large pigments of model paints.
So long folks!
Posted by MikeV on Sunday, July 22, 2007 6:42 PM
Exactly right my friend. Smile,Wink, & Grin [swg]
    May 2005
Posted by Bgrigg on Sunday, July 22, 2007 8:30 PM
I've learned a lot of what I know about airbrushes from you, so I thought you would agree! Big Smile [:D]
So long folks!
    September 2003
Posted by Daywalker on Tuesday, July 24, 2007 12:29 PM
FWIW, I use a fine needle in my 100LG for everything but clearcoats.  I spray mostly acrylics, with some enamels.  I thin them quite a bit, and have never had any problems whether spraying fine detail or general spraying.  In fact, I painted this entire aircraft with the 100LG and a fine needle, and it was the first plane I painted with it:
Up until then, I used a Badger 200 for everyting.  Now, you couldn't pry my 100LG outta my hand for anything!
Frank
    May 2005
Posted by Bgrigg on Tuesday, July 24, 2007 1:09 PM
Wow, nice work. Now you've got me thinking I should put the fine needle in my 100LG!
So long folks!
    September 2003
Posted by Daywalker on Tuesday, July 24, 2007 1:19 PM
Thanks, B!  When I painted the light blue and sand, I did it panel by panel so a large coverage area wasn't needed.  Except for the clears, I haven't touched my 200!
Frank
