Choosing an Airbrush
    August 2007
Posted by SonexAviator on Friday, August 3, 2007 1:51 PM
Any suggestions on what size paint cup I should look for in a detail airbrush.  I am looking at the Iwata HP-BH or the HP-CH.  The B has a 1/16 oz cup and the C has a 1/8 oz cup.  As this is to be used as a "detail brush, will the smaller size be OK?  As good as the Iwata is supposed to be, it may end up being my main brush, but I want to make sure it will meet my needs.  I work in 1/48 aircraft only.  Any help or advise would be appreciated.
Posted by ABARNE on Saturday, August 4, 2007 1:28 AM
Howdy Sonex, welcome to the forums Sign - Welcome [#welcome]
Although I use siphon feed airbrushes, I typically use them with a color cup that is, I believe, 1/4 oz.  In my experience, I often use it at least a third to half full, which makes me think the 1/8 oz would be the better choice.  If you are intending it to maybe be your main airbrush, I would definitely lean toward the larger cup.
Andy
Posted by gjek on Monday, August 6, 2007 12:27 AM
I would go with the HP-Cplus if you think it might become your primary AB. The HP-B has  a .2mm nozzel. That is very small. The HP-C has a .3mm nozzle, larger cup and is more versitile. I have had the HP-B, HP-C, and Iwata's Revolution. The revolution has a .5mm nozzle and does 90% of my AB work. Tha HP-C does my fine detail stuff and I got rid of the HP-B because of the small cup and a nozzle size I didn't use. I bought a .2mm nozzle and needle for the HP-C but have never needed it.    Greg
Msgt USMC Ret M48, M60A1, M1A1
Posted by Anonymous on Monday, August 6, 2007 9:04 PM
If your heart is set on an Iwata and 1/48th is your bag, I would recommend the Eclipse HP-CS.
E
