I haven't had a huge amount of time using the 200-20 yet. I did play a bit and like what I see. Dialing in the line width is ridiculously easy, and I think it's a keeper!
Bleeder valve: Something is not sounding right here. Did the compressor come with an instruction book? No Matter, here's a link to one.
And an excerpt:
1. Assemble No. 24 (D535 Bleeder Valve) to Air
Outlet Port in position as shown on drawing and
tighten securely with Knurled Stem facing up.
2. Open Bleeder Valve by turning Hex Nut, then
Knurled Stem counter-clockwise, approxi-
mately two turns, this prevents compressor
having to start under load. DO NOT close
Bleeder Valve completely as Compressor
may not start under pressure.
