fine lines
fine lines
Posted by Anonymous on Friday, October 5, 2007 1:56 PM
Im using an aztek 320. I also used the tan nozzle ( The one that is suppossed to be for fine lines), But im not happy with the results. Any suggestions
    January 2007
Posted by IYAAYAS on Friday, October 5, 2007 4:21 PM
If you could provide some info, we could help a little better:
Canned air or Compressor?
What PSI are you spraying?
What medium are you using?
Is it thinned?
Posted by Anonymous on Friday, October 5, 2007 4:36 PM
im using a compressor at about 25 PSI. And ive been using MM enamels, and thinned 25%
Posted by MikeV on Friday, October 5, 2007 7:17 PM
I would say try thinning the paint more, about 3:1 or even 2:1 and spray real close to the surface, about 2" away from the surface and maybe 20 PSI or less if possible.
Why did I say 2" Dunce [D)]
Get as close as possible which could be 1/2" or less.
    January 2007
Posted by IYAAYAS on Saturday, October 6, 2007 8:09 AM
I'd start by lowering the psi
Posted by MikeV on Saturday, October 6, 2007 10:37 AM
If it's a siphon-feed airbrush then 20 psi or so is about as low as you can go if you want to reliably draw paint from the cup.
    September 2003
Posted by Daywalker on Saturday, October 6, 2007 10:58 AM
MikeV-
Could I ask a question here about fine lines?  I am not trying to hijack this thread, honest!
I use a Badger 100LG with a fine tip, a compressor, and mostly spray Gunze acrylics through it.  Would you be able to recommend an ideal pressure and paint consistency for doing VERY fine lines with it?  Say, highlighting panel lines or German "squiggle camo"?
Frank
    January 2007
Posted by IYAAYAS on Saturday, October 6, 2007 2:22 PM
Uhhh...Mike...he said he was using 25 psi...
Posted by MikeV on Saturday, October 6, 2007 5:51 PM
 Daywalker wrote:
MikeV-
Get some scrap plastic and practice with pressures I would say.
Try 3:1 of paint to thinner and also 2:1 and see how they spray.
Set the compressor at about 15 psi and see how it does, you may need to adjust the pressure up or down to get the paint to flow well.
Posted by MikeV on Saturday, October 6, 2007 5:52 PM
Yes, and I am saying that much less and that siphon-feed will have trouble picking up paint.
Posted by Anonymous on Monday, October 8, 2007 12:35 PM
What is absolutely hilarious and ironic about this post and the follow ups are that you are both absolutely right.  With the Aztek 320 airbrush, you can use it as either a siphon, side feed, or gravity feed brush.  With the Aztek system, fine lines depend upon paint viscosity, the selected nozzle, and paint feed type.  Some people use higher air pressure and greater distance with a siphon feed system and some use low pressure with a gravity feed system to achieve the same results.  With color cups and side feed systems (this gets kind of lost in translation with the Azteks since they are all technically side feeds) , you have to find a balance that works for your individual technique.
Big E - Owner of 20 airbrushes, each with it's own personality.  4- 100LG IL's, 1- 150 w/ 3 heads, 1- 155 w/ 2 heads, 1- 175 w/3 heads, 3- 200's w/ 3 heads, 1- 350, 1- 250, 1- Paasche H w/ 3 heads, Paasche VL, Iwata Eclipse BCS & CS, Iwata Revolution BCR & CR, and a Model Master ( Aztek ) 470.
    September 2003
Posted by Daywalker on Monday, October 8, 2007 1:28 PM
Thanks Mike!  I'll give those a try. Thumbs Up [tup]
Frank
