Alclad problems
    August 2007
Alclad problems
Posted by Big Mike on Friday, October 19, 2007 10:18 AM
when using alclad they say you must not seal it, but when you mask over it the paint comes off i am using airframe aluminuim colour over tamia white primer, any help would be great
Thanks
South Africa
GO SPRINGBOKS GO!!!
    July 2004
Posted by mucker on Friday, October 19, 2007 12:30 PM
a few questions: Is the Primer acrylic? If so, try sealing the primer with Future.
How long dod you let the primer and the Alclad cure? Let the primer cure for 48-72 hours before spraying the alclad. Then, let the Alclad cure for the same amount.
Hoepfully, this fixes your problem.
    August 2007
Posted by ben1227 on Friday, October 19, 2007 6:13 PM
Oh well with what they say. You have to seal it for decals. Use a glosscoat, dullcoat, or Future.
.:On the Bench:. Tamiya 1/72 M6A1-K
    January 2007
Posted by Gigatron on Friday, October 19, 2007 9:57 PM
Not necessarily true.  Alclad is a pretty slick surface to start with, so there's no big need to to spray it with future for decaling.  The purpose of laying down future is to give the area a flat surface for the decals to adhere to.
What you can do, when working with alclad and other metallizers, is to dip the decal in solvent or future to soften it up and then apply it.  This eliminates the need to spray down a coat and kill the paint job.
-Fred
