MM Acryl paint
    November 2003
MM Acryl paint
Posted by wildcard2 on Saturday, October 20, 2007 11:16 PM
OK so I just tried MM Acryl paint for the first time and I'm using a Paashe VL. With a Testors mini blue comp. This is the nicest paint Testors has ever put out! And its acrylic to boot. WOW! the coverage is spectacular and the finish is as good as enamel or better. and no fumes, so simple to clean up! AWESOME! great adhesion and I didn't even need to thin it,it shot great the first time rightout of the bottle! tip dry was minimal and I didnt use retarder, If you doubt this stuff just try it you'll be glad you did!Angel [angel]Thumbs Up [tup] Mark.
    October 2005
Posted by usmc1371 on Saturday, October 20, 2007 11:55 PM
I agree with you.  I loved MM Acryl.  Unfortunately, for some reason, it always gave me a headache.  I use a spray booth and a respirator, but it still gave me a headache.  I had to switch to Tamiya Acrylics.  For really good adhesion, try priming the model first with a lacquer primer.  Also, be sure to get a bottle of Testors Dried Acrylic Cleaner.  Works great on airbrushes and brushes for cleaning Acryl from them.
Jesse
Posted by MikeV on Sunday, October 21, 2007 12:36 AM
I used to use it but had too many problems with it and switched to Tamiya.
    August 2004
Posted by Tankmaster7 on Sunday, October 21, 2007 9:29 AM
Glad you have good experience with it.
I hate the stuff. Much prefer the MM enamels. Anf for acrylics Tamiya and vallejo are far better IMHO.
But if you have good luck with 'em, keep on going! Thumbs Up [tup]
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    November 2003
Posted by wildcard2 on Sunday, October 21, 2007 2:55 PM
mike... It may simply be a case of beginners luck,I hope not, but I've read many threads that seem to indicate this stuff is sub par? sorry folks I'm just not seeing that ....yet! If I do run into any problems I know just who to call...... thanks MarkMake a Toast [#toast]
    November 2003
Posted by wildcard2 on Sunday, October 21, 2007 2:58 PM
Tankmaster7 Thanks I'll keep you all posted. mark
    August 2007
Posted by ben1227 on Sunday, October 21, 2007 3:26 PM
 I hated MM acrylics. Tip dry, too thick, clogging the airbrush...IMHO Tamiya, Pollyscale, and Gunze are better.
.:On the Bench:. Tamiya 1/72 M6A1-K
Posted by MikeV on Monday, October 22, 2007 12:22 AM
I had some great results and others that were not good, it seems to be inconsistant to me.
This was done with MM Acryl and came out good:
Posted by ABARNE on Monday, October 22, 2007 1:26 AM
I use enamels more than acrylics and generally prefer enamels.  However with my acrylic usage, I haven't seen a lot of difference with airbrushing MM Acryl compared to Tamiya acrylics.  Tamiya may adhere slightly better, although I find MM brush paint a bit better.  Probably the biggest consideration for me is availability of whatever color in which I'm interested.
    August 2007
Posted by ben1227 on Monday, October 22, 2007 5:20 PM
Brush painting is the only thing MM acrylics are good for IMO...
    January 2003
Posted by plasticmod992 on Wednesday, October 24, 2007 4:37 PM
Hey all, been out of action for some time..good to be back in the forums!
Like MikeV, I had mixed results; most notible was my inability to shoot fine lines thorugh my Iwata HP-CR for camo without emmediate tip clogging.  Other than that, the finish and color availability are excellent.  I too have converted to Tamiya acrylics using 91% or Denatured alcohol for thinner and the results have been outstanding.  In an effort to not be discouraging about MM Acryl; if you have found them useful and they perform well for you... great!  So keep up the enjoyment and have fun with them!  I learn something everyday, so please keep us all informed with any tips and advice using MM Acryl!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
